When a 10-bolt breaks......
Old Mar 11, 2007 | 09:35 PM
chipabba's Avatar
Default When a 10-bolt breaks......
When a ten-bolt rear end "breaks", what exactly breaks? Is it the shafts? gears? housing? From what I can gather, most people replace the entire thing in high HP/TQ applications. I would eventually like to put a stroked L92 into my M6 SS. Long prior to that however I want to make sure the rest of the car can handle close to 500 hp/tq.
Old Mar 11, 2007 | 10:28 PM
Smoke Panther's Avatar
usually the teeth get snapped off the ring gear
Old Mar 11, 2007 | 10:36 PM
staringback05's Avatar
bearings will go to.....ive seen cars not move...and cars with one wheel that will move....m6 cars break them alot easier then A4s
Old Mar 11, 2007 | 10:38 PM
Sunset'01Z's Avatar
yea my bearings went out on mine. they were trashed when i pulled them out. probably from doing burnouts and stuff lol.
Old Mar 12, 2007 | 03:38 AM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
When lil metal shards are found inside,......thats from the ring and pinion right?!!
Old Mar 12, 2007 | 03:40 AM
^^^ can be
Old Mar 12, 2007 | 03:55 AM
Well then,...I believe I'll be buy'n some new gears then. lol!....they where stock anyway,....atleast now I'll have an excuse for put'n some 3.73s in now.
Old Mar 12, 2007 | 03:57 AM
anything else that it might be,....like the actual differential itself?
Old Mar 12, 2007 | 06:21 PM
ULTIMATEORANGESS's Avatar
i wiped out everything. gears,bearings, posi ect.
Old Mar 12, 2007 | 06:31 PM
BLKWS.6's Avatar
LMAO, dude, that 1/2'' thick puff of metal shavings on your magnet in there is normal.
Old Mar 12, 2007 | 06:47 PM
Tainted's Avatar
Here goes... I used to have a pic but I dont anymore
My gears locked up, the ring gear had like 6 or 7 teeth break off and it cracked basically in half, the pinion gear broke off complete at the bearing and blew an 11 inch hole THROUGH the housing. the posi litterally shattered the biggest chunk left was about the size of a damn half dollar. then from there it proceded to strip my axles and break the yolk off the end of my driveshaft.
total destruction
and that was just from a hard launch in a almsot stock 96 Z28 A4
Old Mar 12, 2007 | 06:50 PM
Shockwave179's Avatar
The bearings in mine cooked..
Old Mar 12, 2007 | 06:57 PM
MTN_Z's Avatar
I hit a hard 1-2 and it ripped half the teeth off of the ring gear. Posi was equally mangled. I love 10 bolts!
Old Mar 12, 2007 | 10:26 PM
Well... my housing and axle actually got bent so those I actually needed. Egh,...the new housing unit came with a NEW 3rd member anyways so atleast I'm get'n a fresh one. My old rear end had 107,000 miles on it anyway. It was probably on its way out especially after the beating I took it through last summer.
Old Mar 13, 2007 | 12:23 AM
chipabba's Avatar
total destruction
Holy Shiite! That has to be the winner! I wish you still had pictures. Priceless!
Old Mar 13, 2007 | 01:01 AM
2000badbird's Avatar
when a 10 bolt breaks................. a gm engineer is laughing because it is funny
Old Mar 13, 2007 | 01:12 AM
PowerShift408's Avatar
Putting in new gears will not remedy the shittiness in the design of the 10 bolt. It will still explode. It's not the material of the gears, but the actual size of the ring and pinion.
Old Mar 13, 2007 | 01:22 AM
I know,..Egh!,..its a money issue right now. So the 10 bolt will suffice for now!
Old Mar 13, 2007 | 01:24 AM
....yea.........seriously!
Old Mar 13, 2007 | 02:11 AM
XofXtimeX's Avatar
LMAO that made me literaly laugh out loud.
I like how a nissan rear end has a 10 second TT LT1 running it and it broke after MONTHS of track abuse..and the owner just replaced it with another stock one
