The perfect oil.
#62
Originally Posted by Yahelou
so what happened to patman? he said he was gonna do an oil analysis on penzoil platinum, but i havent seen it. did i miss his thread about it? would really like to know what happened with him
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#63
Tech Resident
Originally Posted by Patman
I'm still here!
As was already mentioned, my oil change will be in the fall so I'll post the results then. I am waiting for my oil life monitor to count down to zero, so that will probably be at about the 7000 mile point on the Pennzoil Platinum.
Any issues with consumption? Can you tell if the motor is consuming more or less or about the same as with GC? Can you notice a difference in low end power since Platinum is a good deal thinner than GC?
Sorry for all the questions, Pat
#64
I won't know the consumption until I'm finished the interval, as I've found my dipstick still shows full even when it's a quart low. So based on previous oil changes I know that my engine uses about a quart every 5 or 6k.
It actually does feel a little bit more responsive at lower speeds now, compared to the thicker GC.
#66
I'm running the Platinum 5w30..on my 2nd interval of this. For some reason my car burns this oil faster than any other oil i've tried..which kinda bums me out because i can get such good deals on this oil. My trip from Florida to NC...i burned about half a quart...than on the way back i burned about another 3/4 of a quart. That was the first trip tho i've taken with my 3.42's..so i dont know if it was just the higher RPM that i was turning on the highway that caused me to burn the oil...or if its just from the oil itself. Either way..i have some green GC that i'm gonna use my next oil change..and i'll see if it helps any..if it doesent than i'll switch to Mobil 1 10w40 HM to see if that helps any.
#67
I use Castrol Syntec 10w40 since it gets very hot down here in Southwest Texas and car is over 100,000 miles, I must say that it works very well in my car, must be the climate but I get no piston slap or noisy valve train, it doesn't burn any oil. I'll stick to this oil for a while.
#68
I'm still here!
#71
Originally Posted by WhiteStripes
I've been using the GC since I've had my car which is about a year now. This most recent oil change I decided to throw some of that Lucas Oil Treatment stuff in it... So what does everybody think about these types of additives?
But Lucas is a no no in any engine:
http://bobistheoilguy.com/images/lucas/lucas.htm
#74
thats good. are u using 5w30 penzoil platinum? im actually interested in seeing the results.
#75
Originally Posted by 71velle
Hey how does everyone here feel about royal purple yes no maybe not worth the money ??
#78
Originally Posted by angel71rs
But Lucas is a no no in any engine:http://bobistheoilguy.com/images/lucas/lucas.htm
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
#80
Originally Posted by Dal1as
That's what I just used because I couldn't find the GC. Worried about the CST though. Patman?
If you live in Tejas, the Amsoil Euro 5W-40 would be a great year-'round oil, as would the Red Line 5W-40 (at least for the southern parts of the Lone Star state, as the RL has UBER-high cSts).
