Lights cant turn off
I have the whole lovely when it gets so dark, my headlights turn on automatically, but i cant put the switch in just the middle so the fogs are just on, i do that and the headlights stay on, is there a way to change this?
*copied from a sticky in the electronic section*
Method 1) This method requires no cutting. First, pry up the dashboard near the blinking LED with a small screwdriver.
Near the LED, you'll see the light sensor. Twist the sensor about 1/4 turn and remove it from the dash.
Detach the sensor connector from the wires. Place a small wire or a 10k resister where the sensor was.
Now they won't be on for staging, only when you want them on. You will still have amber running lights.
Method 2) Take your left side vent out. Take the two screws holding your light switch out.
Find the orange/redish wire going to G, cut the wire about 2 inchs from switch. In case you would like to put it back.
