The best Spark Plugs for me
Old 05-13-2007, 09:16 PM
PureWS6's Avatar
Default The best Spark Plugs for me
Question:
I have never replaced the spark plugs on my trans am. The car just came out of storage and I am thinking it is about time to do it. The car is basically stock, with 36k on it. I do not want to continuously replace the spark plugs. I am thinking about the NGK TR55's...but what about platinum or iridiums? I have heard some negative things about these plugs, but is there really a down side for a mostly stock car that will see an occasional race?
Old 05-14-2007, 12:37 AM
nostyta's Avatar
The NGK TR55s should work fine for a stock car as long as your not planning to add nitrous, a lot of people on here run them with no problems. You could go with the platinum or iridiums if you want to spend the extra $$$, they should last longer.
Old 05-14-2007, 01:04 AM
Revelation Z28's Avatar
when i did LTs i didnt have luck with platinum AC delcos. gave me backfire and a bad miss under WOT.
TR-55's will be your best shot. TR-6 when you want n2o
Old 05-14-2007, 01:24 AM
Kage's Avatar
Cool
Originally Posted by PureWS6
Question:
I'd go with NGK Iridiums. No probs here at all, and she idles a lot smoother. But then again i slapped MSD's 8.5mm at the same time i changed the plugs.
Old 05-14-2007, 01:33 AM
SHINER's Avatar
I like TR6s now cause i got 5.3L heads and higher compression with my Torquer cam.
TR55's are good for N/A stock(no gas).
Anything else use a TR6 and they even have others(cant think of the name) that have the option of having a projected tip or a non projected tip.
Really all depends on your setup and what your planning on doing.
Old 05-14-2007, 10:24 AM
PureWS6's Avatar
Ok I think I am going to go with the TR55IX. What should I gap them at?
Old 05-14-2007, 10:32 AM
Kage's Avatar
Cool
Their factory pre-gapped. Just slap 'em in.
Old 05-14-2007, 03:19 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I swear by AC/DELCO IRIDIUMS....4 changes and they all looked good when pulled.
Old 05-14-2007, 05:12 PM
StealthZ06's Avatar
NGK TR55's
Don't bother with the iridiums.
Old 05-14-2007, 05:34 PM
BriancWS6's Avatar
I would recommend NGK TR55s gapped at .055 for your application.
Old 05-14-2007, 10:19 PM
PureWS6's Avatar
Why shouldn't I bother with the iridiums? I really don't want to be changing my plugs seasonally.
Old 05-14-2007, 10:53 PM
Kage's Avatar
Cool
You tell 'em my brotha.
Go with Mike he might even give u a better deal.
http://www.ws6project.com/user_stor/...d1d5345e174108
Old 05-15-2007, 05:41 PM
Moderator
davered00ss's Avatar
TR55's. The TR55 IX (irridium) plugs are great too.
Old 05-17-2007, 11:34 AM
Desert Rat's Avatar
Can you get that passenger side bank done without removing AC lines?
Old 05-17-2007, 06:32 PM
angel71rs's Avatar
Yes. Just unbolt the AIR tube from the exhaust manifold to get it out of the way.
Old 05-17-2007, 06:38 PM
LS199Z28's Avatar
I use NGK Iridiums with MSD coil packs and 8.5 wires, the motor is stock for now. The NGK Iridiums are pre gapped like Kage said so it is kind of like plug and play.
Old 05-18-2007, 09:04 AM
PEANUT's Avatar
whats a good plug for a 75-150 (dry)shot of spray on an all stock 2001 ls1, I still want the car to run well on motor though...
Old 05-18-2007, 04:07 PM
Marblehead's Avatar
Go with the AC Delco stock plugs. They are iridium tipped, gapped at .040, do not re-gap them. You can't go wrong with them and they will last, even under hard driving. I just put them in my LS1 with MSD wires. If installing aftermarket wires, leave the metal heat shields off or else there will be too much tension on the wires and they may pop off. MSD's boots are a little longer which is why the wires is stretched a little with the heat shield on. Don't need the heat shield with MSD's anyway.
Old 05-25-2007, 07:37 PM
AXE20's Avatar
What do you think about NGKtr5 for ls1 Heads & cam (239/242)
Old 05-25-2007, 08:00 PM
lovescamaros28's Avatar
Ngk T55's
Quick Reply: The best Spark Plugs for me
