oil pressure
LS1Tech Administrator
Received 1,493 Likes
Originally Posted by fuseone
hi normaly my oil pressure is around 40 psi but now its in like 35 psi would it be because the weather is getting hotter out now
Originally Posted by 5_02ls1
"Who needs a new oil pump, just put a new sending unit "
any 98 ls1 owner
any 98 ls1 owner
All '98-'00 use the same oil pump. It is not '98 specific.
IMO, there is no reason to replace the pump in a '98-00 engine unless you're already in there doing a cam swap or you have some serious low oil pressure issues. Just being a '98-'00 engine alone doesn't warrant a pump swap. Tons of '98-'00 cars have 80-150k miles on the stock pump without issue.
Originally Posted by letsrun97z
mine sits at a hair above red when its at 210d and about 10 at 180 @ idle is that bad??
its is an lt1 everyone say's that they sit lower then the ls1 it goes right up to 50 a wot just sits real low when hot just put m1 5-30 in it yesterday im going to do another oil change in a lil bit not sure what i want to go with 108k on motor
