removing centre console
Old May 17, 2007 | 08:21 PM
2000sscamarovert's Avatar
Default removing centre console
do you have to remove the revot in the e-brake handle so you can remove console ..
thanks Clint
Old May 17, 2007 | 09:03 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Nope...just pull the e-brake handle as straight up as you can, and you'll be able to pull the center console up over it.
Old May 17, 2007 | 09:06 PM
hmmm ihave done that and i cannot pass the seat even fully reclined!!!
lastcall190's Avatar
When you think you've pulled it all the way, it can probably go further Definitely requires some "finessing" of the console, even when the ebrake is pulled all the way up. Your console will probably take a hit.
EDIT: Try lifting from the back of the console, while slightly pulling it towards the rear of the car.
-J
Old May 18, 2007 | 02:14 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
It's a little tougher if the car is an A4 but it can still be done
Old May 18, 2007 | 02:43 PM
ddcook07's Avatar
how do you get it past the shift **** or do you have to unbolt the shifter
Old May 18, 2007 | 03:20 PM
Viper's Avatar
Take the shift **** off. No need to undo the entire shifter.
Old May 18, 2007 | 03:24 PM
2001NBMZ28's Avatar
ddcook07 - Remove the A4 shift handle - just pull the staple out in front of the shifter handle and pull straight up. Easier if you turn the key on and put it in first gear.
Old May 18, 2007 | 04:54 PM
razorclaw99's Avatar
i pulled my ebrake up..so high i snapped it
Old May 18, 2007 | 07:45 PM
tasilver's Avatar
snapped mine too. then I read on a site a few weeks later that if you leave the e-brake down there is some type of lever you can release the tention on and you can pull the e-brake straight up . wish I had .
Old May 18, 2007 | 08:37 PM
MTN_Z's Avatar
I can get my e-brake more than high enough without snapping anything. Like was said earlier, pull back a little and lift from the back. It will help get the console over the e-brake sooner. You definitely have to use finesse though. No sense in rushing it and breaking something.
Old May 18, 2007 | 10:20 PM
Old May 19, 2007 | 01:02 AM
TheSecretFormula's Avatar
There is a detent in the e brake. You just release it with a screwdriver and you can pull all the way up on the handle without breaking anything. Look at the shifter install write up on install university and it shows how to do it.
Old May 19, 2007 | 05:55 PM
justin quick's Avatar
how bout a base ball bat and about 30 seconds? just kidding
Old May 20, 2007 | 11:15 PM
Shallow Bay's Avatar
Exactly what I was going to say.
http://www.installuniversity.com/ins...er_install.htm
Old May 21, 2007 | 01:57 AM
Strahley's Avatar
Originally Posted by Shallow Bay
Exactly what I was going to post
Old May 21, 2007 | 03:22 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to Rookie Tech
