pop in reverse
Old Jun 5, 2007 | 09:45 AM
bow125106's Avatar
Default pop in reverse
When i put my car in reverse (z28) i sometimes hear a poppin kind of sound...sounds almost like the brakes are grabbing ..can hear it on both sides of the car near the wheel.........its only in reverse and only sometimes...any ideas
Old Jun 5, 2007 | 12:46 PM
stockerws6's Avatar
I have the same noise in reverse also. Seems to occur more when I am backing up and slightly turning the wheels. Any advice would be great!
Old Jun 5, 2007 | 01:17 PM
5301113's Avatar
Same problem here.
Anyone
Old Jun 5, 2007 | 01:18 PM
1WICKDZ's Avatar
does it jolt the car at all?
Old Jun 5, 2007 | 01:26 PM
stockerws6's Avatar
Not really, but it is very noticeable. Almost sounds like something is binding up in the brake/wheel area. Not sure if maybe it could be a bad suspension part such as tie rod or ball joint. I also have 88K miles with stock springs/shocks.
Old Jun 5, 2007 | 01:27 PM
LS1 Freak's Avatar
it must be a chevy thing, my SS even with 22K miles does the same thing, who knows
Old Jun 5, 2007 | 03:51 PM
bow125106's Avatar
Default popping
i just started noticing mine.....it almost sounds like the posi it popping in and out....mine also seems to do it worse when i turn the wheels....I'm trying to sell my car and want to make sure this is nothing serious before i sell..
Old Jun 6, 2007 | 09:32 PM
BriancWS6's Avatar
Do you guys with the popping have M6 cars? Last summer I was hearing a pop or creaking noise somewhere towards the rear of the car. Whenever I would start to let out the clutch and go backwards, I would hear it. Sometimes worse than others. I was afraid it was the posi or something. I got the car on jackstands and started going over everything with a wrench, and it wound up being loose torque arm bolts, where it mounts to the rear. I used some loc tite and tightened them up, problem solved.
Old Jun 6, 2007 | 10:18 PM
stockerws6's Avatar
I have an A4 but will check the torque arm bolts. Thanks!
Old Jun 6, 2007 | 10:23 PM
BriancWS6's Avatar
No problem I also had an a4 prior to my m6. I always heard a metallic ring/pop sound when I backed up with it. I always thought it was odd, but it held 1.6 60fts no problem.
Old Jun 9, 2007 | 03:19 PM
bow125106's Avatar
Default .
any other suggestions???
Old Jun 9, 2007 | 09:32 PM
Baron Von Doolgas's Avatar
see if the u-joint bearings are worn
Old Jun 10, 2007 | 02:54 AM
Revelation Z28's Avatar
i get it when its cold.
i think its the poly bushings i have from the UMI parts.
Old Jun 10, 2007 | 08:34 AM
bow125106's Avatar
Default ?
UMI??? what does that stand for...Also, mine doesnt always do it..the other day i was going to let a guy listen to it and it never would do it. so i put it in reverse, turned th wheels and kinda power braked it...then when i started backing up it would do it
Old Jun 10, 2007 | 05:14 PM
BriancWS6's Avatar
UMI is an aftermarket suspension manufacturer.
