Gear Question
Old Jul 23, 2007 | 04:55 PM
chevyryda2002ss's Avatar
Default Gear Question
I have an 02 SS my pinion seals leaking and the dealer found metal in my diff when i went to get it service i may need to replace a few gears in my diff. My question is should I replace my gears with the stock ones or something better also would it be possible to replace them with the vett gears?
Old Jul 23, 2007 | 04:59 PM
99zee's Avatar
If you have to replace them I would upgrade while your at it. What gear do you have now?
Old Jul 23, 2007 | 05:08 PM
2001NBMZ28's Avatar
Pinion seal leaks are common, mine leaks but not enough to drip on the driveway. What metal in the diff - just small shavings on the magnet inside the cover? If it was serious I'd think the dealer would've freaked out and recommended extensive repairs.
Old Jul 23, 2007 | 05:20 PM
styoung's Avatar
a little of metal in the rear is really nothing to worry about, that is just wear on the gears. i would just have them fix the pinion seal and be done with it.
Old Jul 23, 2007 | 05:22 PM
WELL THE DEALER SAID that they would have to take my diff apart to find out what gears are worn....the car is fully stock besides the slp below i also have to replace my wheel hub bearings which are going to cost me 452buccs just for parts.
Old Jul 23, 2007 | 05:43 PM
styoung's Avatar
i dont trust dealers, id tell them to show you whats going on.
Old Jul 24, 2007 | 09:27 AM
Me neither dont trust them at all. I went back to the dealer yesterday to tell them to explain in detail my service ticket and he said that the bearings in my diff are bad which i can hear those but when i talked to them on the phone before I picked my car up they said something different. Im just gonna go to a different dealer and see what they say...thanks for the tips.
Old Jul 30, 2007 | 10:42 AM
well i fixed the problem this weekend myself turned out to be my axle the diff is in perfect condition...the dealer played me, once i got under there the bolts on my diff werent even touched they never took the cover off.
Old Jul 30, 2007 | 04:34 PM
staringback05's Avatar
you can tell if gears are worn by just taking the cover off anyway...you dont need to take the carrier out
