!AIR Gone WRONG!
Old Jul 27, 2007 | 05:00 PM
2000Z28ls1's Avatar
Default !AIR Gone WRONG!
Well for the last 4 hours and 30 min I have been changin my spark plugs and wires so I fiugred id do the AIR mod well the I got it all off fine went to put the block plates back on got on fine but the drivers side wasnt snug and was moving and causing a leak so I took it off and found that the old gasket was shitty so I pryed that off and tryed to flatten it out and put it back on well still didnt work so I try to take it all off again and the front bolt Broke Idk what to do I got the back one out, carefully I might add, and put 3 washers to hold down the block off plate better but it still leaks really bad so anyone have any ideas? should I try to get a new gasket and stick it on or will just one Bolt not hold down the plate? Any help would really be appriated or are there bolts that are fairly small and easy to thread?The front screw is sticking up slightly maybe enough to thread a bolt on it.
Old Jul 27, 2007 | 05:05 PM
5_02ls1's Avatar
orange high temp rtv works good on exhaust gaskets.....id get a small easy out kit and try to remove that bolt......
Old Jul 27, 2007 | 05:11 PM
2000Z28ls1's Avatar
Where can I get that sealent? think homedepot lows or sears?
Old Jul 27, 2007 | 05:12 PM
2000Z28ls1's Avatar
or RTV and where can I get that easy out bolt kit? sorry im kinda mad I got all these new plugs and wires looking forward to cruisin with some more power and now I have a crappy exaust leak click and lack of power
Old Jul 27, 2007 | 05:33 PM
2001NBMZ28's Avatar
I'd visit the dealer. Get new gaskets 12553617 (cheap). For a proper seal you need both bolts - so you'll need a new one and have to get the broken one out.
Old Jul 27, 2007 | 06:38 PM
Sparetire's Avatar
A lot of the time with broken bolts, its easier to justgo to the machine shop and pay them 20 bucks. they have the good tools and broken bolts are a major frustration.
And its pretty neccesary to get two bolts holding down that thing. RTV alone does not do much.
2000Z28ls1's Avatar
I bought some JB weld and im gonna put that on it hopefully itll seal pretty well for the time being.Hope to order long tubes soon!
Old Jul 27, 2007 | 07:31 PM
donalr76's Avatar
Drill the bolt out if you didn't break it high enough to get some vice grips on it. Or order some longtubes and y-pipe immediately.
Old Jul 27, 2007 | 08:10 PM
Rhoop24's Avatar
Time for some headers.
Old Jul 27, 2007 | 08:31 PM
2000Z28ls1's Avatar
Yeah Header time is gonna be coming up alittle sooner than expected
Old Jul 28, 2007 | 12:32 AM
djsanchez2's Avatar
Could not have said it better myself.
Try using liquid wrench and the above mentioned. Resort to drilling if the bolt starts breaking shredding off w/ the vise-grips
