Best first suspension upgrade...
Just curious, i've been fiddlin' w/ the engine plenty (Headers, intake, cam and heads coming this Xmas, 3.73 rear), but i want to make sure all that power connects w/ the ground and doesn't fly up in a cloud of smoke.
So i ask, what should be my first suspension upgrade for my 99 WS-6? Also, how much do you think it's gonna cost me to stick 400+ HP to the ground (daily driver)?
Originally Posted by The Black Mamba
9"...
As far as lower control arms (i'm guessing that's rear, not front) and subframe connectors, should that run me over $300?
Well im assuming from your original post you want a suspension for straight line traction, and not corner carving/handling.
In this case ditch your front sway bar, add LCAs, torque arm, and or Panhard and some soft sticky tires and you have a good start. look at UMI stuff if you wanna save money they are pretty cheap compared to alot of the others..
Thanks for the help.
if you wanna corner carve, it cant really be had on the cheap...
good springs/shock combo. new front/rear sways
its hard to do both... read the sticky in the suspension section
i tried to comprimise and get a decent all around setup in mine, now im having problems deciding on a good all around shock/spring combo... seems they are either for cornering or drag setups, and my car is a little of both as i suspect many of ours are. im leaning toward HD Bilsteins, and a front lowering shock and the heater hose mod for the rear with the stock shock... i dont mean to hijack, its just ive been thinking about this topic lately...
