Loud belt sound in engine bay
LS1Tech Administrator
Received 1,806 Likes
I think that the belt is original. The nose is a chirping noise and also just over all loud. I am going to try and lube it up tomorrow and see if that subdues the noise and go from there
Spray the belts with belt dressing while the motor is idling. If the noise goes away a belt is glazed and needs to be replaced to quiet it down. If it continues then use a stethoscope or put your ear on the handle of a long screwdriver and the other end on the alternator, water pump, PS pump, ETC. until you find out where the noise is coming from.
