2nd gear start?
if im moving at all, even a creep i go from second (even from a dead stop sometimes) just a lil higher in the rpm's and let the clutch out the same. the way i see it, if you dont wanna shift, get an auto, its callled a "manuel transmission" for a reason. =] and slap your buddy to ensure he never does it again
Nobody should ever touch your shifter unless you let them(I let my girlfriend shift sometimes to get a feel for it, I'm in the process of teaching her to drive a manual...while my clutch is on the chopping block so I gotta teach her to shift)... thats just rude/inconsiderate/dangerous. Anyway, I can see starting in 2nd to save gas, but it would be at the expense of your clutch, so why bother? When I'm driving to save gas, I go from 1st to 3rd or 4th... seems about the same as going from 2nd to 4th or 5th.
your friend is dumb and lazy just because it can do it doesn't mean it should be done that way your clutch will thank you in the long run
i've accidently started my car in third one time haha it didn't do too bad actually
and to the poster who asked why you should keep you car in neutral at stoplights with the clutch out is because leaving it in gear with the clutch in puts unneeded wear and tear on on the throwout and pilot bearing
im a firm believer in leaving the car in gear at a stop. Reason being for the simple reason, if the car is in neutral, and persay you get rear ended, your car is going to roll into the intersection, and chances are your going to get t-boned. I leave it in gear, for the reason of if you do get rear ended, chances are your foot is going too fall off the clutch, and mos likelly stall the car, keeping it from rolling. There is a little bit of excess wear, but IMHO its worth it.
I always start in 1st unless its snowed/slick outside then i start in 2nd. Even with 4:10's 2nd on dry pavement I have to unnecessarily ride the clutch ('cause of the cam).
#33
#34
if the car is in neutral, itll roll dude......think about it. if your getting rear ended, and your in the front of the line, last thing your gonna have on your mid at that instinct it to hold the brake pedal down if it is a decent impact. Anyways, thats just my .02
#35
Whatever, back on topic.
#37
ya we got something called brakes they are for stop signs, redlights and other stops
the only time im bad is on hills for about 1-2 seconds the car might be held by the clutch I hate doing it but coming up to my house there is a 4 way hill and then i park facing down on a pretty good slope so I cant win either way
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#39
Waiting in gear doesnt hurt anything on our cars. With the older cars that had clutch cables it would cause them to stretch faster so they had to be adjusted more often Not a problem with our cars. As long as it is all the way in.
#40
Hell yes on the AVATAR! Anyhow I gave the guy a talk about the clutch slipping and buring it up faster and what not but he brushed it off. The worst part was he said "Dude I always started in 2nd in my prom car so I wouldn't have to shift right away." He had a RSX type S. I thought to my self does this look or sound like a mother freaking ricer but I was nice and just smiled and kept starting in 1st. He will learn.
