Ls6 ?
as for the clutch, 01 and 02's had an LS6 clutch and upgraded master and slave.
as for the LS6 blocks, thats all it was was the blocks, no heads, cam or anything else....dont hold out to find one with an LS6 block cause its not worth it.
I'd get a 01-02 car as most all of the problems were ironed out by then. Stronger rod bolts, better oil pumps, and minor if any piston slap.
Re'
I have never heard of any full ls6's coming form the factory in a camaro or TA; only the blocks.
01- 02's as stated have the ls6 intake...
98's had weaker rod bolts...
the 98's pcm is a little more resilient to tuning, and u'll find alot of handheld tuners do not work with 98's (or 97 corvettes)
even if you found an 01-02 fbody that had an ls6 block, it would not produce anymore more power than a fbody with ls1 block, so don't put a thought into it.
FWIW, i own a 98, and got a smokin deal on it... like i said, if you find a good deal on a clean ls1 fbody, take it, there's not a big enough difference between the years to justify passing up a good deal and paying out the *** for a 02 model...
