Got 2 problems....
1- I was taking the parking lights out today to get the 3 yes 3 burnt out bulbs. Well I took all of the 40 bolts out that hold all of the plastic junk under the car out. I disconnected the 2 bulbs. Took the 3 bolts the hold the actual housing in, and now it just wiggles around in there. Its pretty loose but I cant manage to pull the whole thing out. The reason why I want to get it out is cause one of the bulbs broke in it, and there is a ton of moisture in the housings. What do you suggest?
2- I took my car to the dealership to get a new key fob programed and it works great, except the fact when I unlock my car and I slam the door shut the alarm will go off. It only happens when I unlock it, wait about 30 seconds and the lights flash then if I slam the door the alarm goes off?
What do you guys suggest?
Thanks
M
Thanks
M
2-take it back to the dealership
Just another quick question, how much torque does a stock LS1 make?
Thanks!
And as for the parking lights, I had to take the headlights out and get them from the top, then I had to get some pliers and push together where the bumper and the fender come together. then one side of the parking light would pull out. I think it was just the aftermarket bumper that was holding it up.
Thanks for the help tho!!!
M
Also, with these cars I wouldn't ever slam the door. They're not as heavy as they look and the window regulators are very fragile. A couple good slams and your windows are going to rattling over every little bump
I think I am gonna just disconnect the stock alarm system
