Somebody Help?!
Old Aug 9, 2003 | 08:36 PM
badazzws6's Avatar
Default Somebody Help?!
Just bought a 99 ws6.So far I got a lid,and a cutout,and some free mods.So me and my friend went to the track,I ran a 13.3 @106.9mph.I heard thats a pretty descent time.So does anybody have any sugg?I think Im going to get some 4.10's and a set of nittos for the track.
Old Aug 9, 2003 | 08:56 PM
NightHawk's Avatar
Default Re: Somebody Help?!
Is it an M6 or an A4?
That time sounds about right, but you could probably do better with some practice.
Nittos are a good idea, and so are 4.10's if you have an M6. If it's an A4, then 3.73 is the most you'd want to go.
Old Aug 9, 2003 | 08:57 PM
bigMAC's Avatar
Is your car an auto or a 6 speed? If it is an auto, get a torque convertor. You should get a set of headers too.
Old Aug 9, 2003 | 09:14 PM
badazzws6's Avatar
Yes.its a six speed.I know my times could be much better,but I kept bogging off the line.What do you think I should do to get a better launch?
Old Aug 9, 2003 | 10:39 PM
Blk00WS6's Avatar
Nice times. I personally wouldn't add 4.10's until i added a Cam but it's up to you.
Old Aug 9, 2003 | 10:59 PM
badazzws6's Avatar
So if I shouldnt get 4.10s should I get 3.73s or keep my stock 3.42s.My mechanic said Id see a big improvement in track times with some 4.10s and some drags(nittos).Any SUGG?
Old Aug 9, 2003 | 11:05 PM
01redws6ta's Avatar
I've heard 4.10's and Nittos will get you a busted rear end or even more!
Old Aug 9, 2003 | 11:14 PM
badazzws6's Avatar
So should I just stick with my stock 3.42s or an aftermarket 3.73?
Old Aug 10, 2003 | 02:29 AM
JaxWS6's Avatar
From what I know and learned from this site, you probably won't find much of a difference in the 3.73 gear. If you go for gears go for the 4:10s.
Old Aug 10, 2003 | 05:50 AM
DD966's Avatar
Your times are similar to mine. I've only been to the track once in this car. Your 60' time will determine if you need to change your rearend. Personally, I'm just changing tires, and practicing first. I suggest you do the same. Just my 2 cents.
Old Aug 10, 2003 | 11:37 AM
badazzws6's Avatar
So should I just get some nittos for now with my stock rearend,that way I could launch a git higher and not peel for my whole 60 foot.When I ran the 13.3 my 60 foot was a 1.9.I heard that a little high i should be more around the 1.7s.
99' ws6 m6
SLP lid,flowtech cutout,free mods
Best E/T:13.3@106.9mph
Old Aug 11, 2003 | 03:38 AM
DONAIMIAN's Avatar
With a set of nittos im sure you can get in the 12's. Hell I honestly think that you can do it without the nittos, just some more time behind the wheel.
Old Aug 12, 2003 | 02:00 AM
badazzws6's Avatar
with the mods i have in my car,are my times descent? I know they could be better because I was bogging off the line alot.But i feel if I launch any higher im just gonna peel.ANY SUGGESTIONS?
Old Aug 12, 2003 | 10:32 PM
onebadz's Avatar
if you got a gear swap i would go with 3.73s because they will be a much stronger gear being that the pinion gear is a little larger vs. the smaller 4.10 pinion. If you run the 4.10 you will be more likely to have rear end truble
