new here
Old May 25, 2008 | 09:09 PM
Big Black SS's Avatar
Default new here
hi every one just got a 99 SS from a small car lot ,SS has a few issues but nothing major i hope , clutch is sticking when i run it hard can anyone tell me why?
Old May 25, 2008 | 09:22 PM
*98TransAm*'s Avatar
you need to do the drill mod
Old May 25, 2008 | 09:27 PM
The drill mod is where you drill out the restriction in the braided stainless line that connects the master to the slave. There is a write up with pictures at
http://www.installuniversity.com/ins...sity/index.htm
click install documents then scroll down to drill mod with mcleod master install
Old May 25, 2008 | 09:30 PM
thank you very much i will look it up .....
Old May 25, 2008 | 09:41 PM
no problem!!
for some reason gm decided to use small lines which results in not enough fluid flow(at high rpms) which then results in a very sticky clutch pedal. this mod is highly recommended.
Old May 25, 2008 | 10:16 PM
406malibu's Avatar
Originally Posted by *98TransAm*
no problem!!
ive been wondering about that for a while on my car... thanks. one question, do you have to get the mcleod master cylinder, or can you just do the drill mod and reinstall the factory one? if thats the case i know what i'll be doing next weekend
Old May 25, 2008 | 11:38 PM
you dont need to get a new master cylinder, (although it is recommended especially if you have high miles or if you do alot of racing). the drill mod itself will eliminate alot of that stiff/sticky pedal.
Old May 26, 2008 | 06:21 AM
406malibu's Avatar
cool, thanks.
