A good daily driver with these Mods??
Procharger model D1SC with twin intercoolers (8 rib system at 7 psi capable of quite more)
- Racetronix upgraded fuel pump
- 60 lbs injectors
- ATI Pro harmonic balancer
- Kooks 1/78 headers
- Hooker 3” y pipe with high flow catalytic converters
- Magnaflow cat-back exhaust
Comp Cam..228/236-115
textralia clutch
Thanks in advance....
- 60 lbs injectors
textralia clutch
You will be fine, watch boost levels and have a decent gas budget. The daily driver aspect of it should be fine at those power levels. Especially since superchargers are fairly broad in power ranges.
As long as you have a good tuner it should be fine. Those injectors seem a little overkill but as long as they are flow matched and your tuner can keep fine control of them you'll be fine. If I was going to DD it, I would size down on the cam and injectors slightly.
Its an m6! I have a maggie w/ almost the same mods and run 9.5#s and get 27 mpg on the highway and 19 in town. I get 17 consistently in town beating on the car. And I have 3.90 gears.
I do agree w/ 99 about the injs, but as far as mileage dont sweat it, it aint bad at all.
Doug
Doug
