Engine Identifciation
Old Jul 26, 2008 | 06:09 PM
J's Metallic Blue 99's Avatar
Default Engine Identifciation
I just started getting into my new project, a1999 Trans Am. I have to replace the cradle so I pulled the alternator to make it easier. I noticed a 6.0L cast into the block on the drivers side.
http://i212.photobucket.com/albums/c...a/P1010044.jpg
I do not know where any of the engine codes are located since this is my first project of this kind. There is not a # cast into the heads but there is a "0113" cast into the block just in front of the passenger side head. Can someone please help me identify this motor?
Old Jul 26, 2008 | 08:37 PM
There also seems to be a "317" stamped into the head at the rear of the drivers side.
Old Jul 26, 2008 | 09:08 PM
NBM-LS1's Avatar
any pictures of the top?
NBM-LS1's Avatar
Im thinking its the ls2 but i can be wrong.
Old Jul 26, 2008 | 09:22 PM
Jenns01TA's Avatar
NBM-LS1 - I am thinking the same thing.
OP - Can you get pics of any other casting stamps? Is there a 243 stamped on the heads?
I thought it was an LS2 also but it has a cast iron block.
No pics of the top but here is what started my search...It's on the drivers side front of the block.
Old Jul 26, 2008 | 09:29 PM
no, tried to get behind the cylinder head but didn't ave any luck. "317" is stamped on the heads.
Old Jul 26, 2008 | 09:42 PM
Jenns01TA's Avatar
https://ls1tech.com/forums/showthrea...&highlight=706
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Material: Aluminimum
Part Number:
12572035
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Old Jul 26, 2008 | 10:00 PM
So is it an advantage or a disadvantage to have it in the car? Does the lq4 produce more HP than the LS1?
Old Jul 26, 2008 | 10:23 PM
Jenns01TA's Avatar
Not off the shelf "as is"... 300-325 hp and 360-370 ft.lb tq.
An advantage to the vortec 6000 series engine over the LSx family is the ability to overbore for NA build-ups. It is a plentiful engine and much more inexpensive than the LS1/LS2. It's not a bad thing, but it is certainly not a LSx.
Good luck with the project.
Old Jul 26, 2008 | 10:30 PM
Well I hope the fool who crashed it into a pole did more than just swap motors. Wish I knew the owner who last drove this thing was so I could find out. I guess thats what happens when you inherit a project...This has been sitting for a couple years so who knows...
Thanks for the help!
Old Jul 27, 2008 | 08:30 AM
deadmanTA's Avatar
That cast iron block is good for forced induction. it's alot stronger. You have 366 cubes, get a cam and a nice set of heads. You'll see some nice numbers out of it. I would see this as an advantage!
Old Jul 27, 2008 | 02:33 PM
406malibu's Avatar
X2 id be more than happy if i looked under my hood and a 6.0 L magically appeared
