emission test failed
Old Jul 31, 2008 | 08:45 AM
murzyn123's Avatar
Default emission test failed
2001 WS6 6-speed,cammed,headers new cat's new front O2's the car failed on idle basicaly its running rich most likely due to the cam or there might be a tune from the previous owner i need to lean it out a bit
can you guys think of anything
thanks matt
Old Jul 31, 2008 | 08:54 AM
Jon5212's Avatar
Where do you live? If you have an aggressive cam/headers you are most likely to fail no matter what.
Old Jul 31, 2008 | 08:58 AM
murzyn123's Avatar
i live in ontario canada and my cam is pretty mild don't know the specs on it since i've bought it like that but its not a monster
Old Jul 31, 2008 | 10:25 AM
Arctic2002ss's Avatar
Sounds to me like it needs tuned. A tuner can take care of any SES, codes, and "not ready" too.
Old Jul 31, 2008 | 10:36 AM
murzyn123's Avatar
i got no codes had the car scanned, i can probably get it tuned lean get a emission test and get it retuned but its gonna cost alot trying to get it to pass with less $$$
Old Jul 31, 2008 | 11:19 AM
1BadAzzWS6's Avatar
Dunno about where you live, but in Maryland they will give you a waiver if your car is lowered b/c they won't risk driving it into the station over the rollers.
Also a good tuner should be able to take car of the SES codes and get your idle right.
Old Aug 2, 2008 | 03:31 PM
sreve's Avatar
rig the air pump to run anytime the engine is running. that may be enough to get you past the test. then change it back.
Old Aug 5, 2008 | 12:22 PM
murzyn123's Avatar
it passed i had the pcm flashed since there was a tune on it that was running on open loop 24 deg timing all the time i bumped the rpm's up to 1050 and it passed
