1999 ws6 inner door panel removal
there are about 6 screws that you need to remove. the door panel has little plastic hooks on the door, what you do is after the screws are removed, pull a little on the handle towards you, you will see that its loose. you will want to pull up on the bottom to get the hooks out of the metal slots in the door. its pretty simple after that. then you do the opposite to put it back together.
EDIT: I forgot you said T/A, idk if its the same, im sure it is, just maybe different screw locations or something? someone will come in here with more T/a knowledge.
remove window/mirror switch, unscrew a couple screws, pull out the tab for the lock, pull up and away. real simple. take your time, dont break the lock tab like i did. thank god for gorilla glue.
