Header install weird feeling?
That bump stock is a horrible waste of money. You can do the poly mounts to get rid of the banging. Just to let you know, its going to suck when and if you put a new trans in. Its pretty impossible to get to some of the housing bolts since it doesn't allow the motor to angle down. I have some crazy cuts and sore muscles from that.
ok here a vid of under the car while its parked and my brother reving.. i think i will take off the clamps since the pipes have been welded but ima make sure its ok to take them off... sorry for the camera movement in the beginning but the floor was hot...lol
http://www.youtube.com/watch?v=kPWMbbNBRLA
if you want a easy fix or a temp fix
you can go to any parts store and get some heater hose and put it in between the y pipe and the floorboard and that will get rid of the banging![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I did my LT's about 2 weeks ago and I did this and it stopped the banging noise,
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If you need pointers when putting them in shoot me a pm, I just helped my buddy do a header install and poly mount swap a couple weeks ago. Good luck with it.
