Car Sputtering
Old Sep 18, 2008 | 03:28 PM
christrusler's Avatar
Default Car Sputtering
2000 Camaro Z28
My car is sputtering when i start off from a complete stop, i've checked all the plug wires and they're on good. Is this a bad maf ?
Old Sep 18, 2008 | 03:37 PM
nemss1's Avatar
it is a good possibity it could be your MAF. it could also be anything on the fuel system causing the engine to not get enough fuel (injector, fuel filter, fuel pump) check your fuel pressure at the fuel rails
Old Sep 18, 2008 | 05:11 PM
How do i check the fuel pressure? When i accelerate it takes off, but sputters a little bit in the lower rpm
Old Sep 18, 2008 | 05:21 PM
DeepV's Avatar
have you checked the plugs themselves?
Old Sep 18, 2008 | 06:12 PM
nemss1's Avatar
there is a fitting on the driver side fuel rail. u just connect a fuel pressure gauge on the fitting
ya check your spark plugs and o2 sensors also
Old Sep 18, 2008 | 07:53 PM
Yahelou's Avatar
check ur o2 sensors. my car was sputting in the beginnin when i turned on the car and would feel like it was about to die. i changed the o2 sensors and it seems like it fixed it.
Old Sep 18, 2008 | 08:01 PM
LS184's Avatar
throwing any codes?.....check o2's
Old Sep 18, 2008 | 08:26 PM
not throwing any codes, will check plugs . How do i check the o2's ?
