shreveport/bossier hang out!
#8043
That sucks man. My buddy might need some tinting done still.
http://www.outlawdivision.com/forums....php?f=4&t=678
I'll send him a text and find out for ya.
#8044
I got my wisdom teeth taken out today so I'm sorta knocked out for today and tommorow, but Sat or Sun I could hang out if anyone is up for hanging out and maby taking a look at my car, let me know what a POS it is LOL cell is -5\1\6-3/8/0-4/8/2/9-
#8045
I just pulled my rear out! Anyone want a10 bolt cheap!!!!! TCS ABS Rear, Its the housing, Axles, gears and posi missing some spider gears teeth! Will throw in a T/A dif cover that will need some minor alu tig welding. LOL A bolt cam lose b4 and cracked the cover good and i had it welded back and then i had another bolt come loose and crack it again lol but it was small i and i put some RTV on it and didnt leak lol.
#8046
stfu sorry to hear about that man im thinking about tinting my truck so ill keep ya in mind.
--- (SICLSX) you get used to it after a while. it was a little aggrivating in parking lots and turning at stop signs etc. but its not so bad
#8050
have no clue! 1st time 2 bolts backed out and broke off and didnt hurt anything and it was all original. So i pulled it apart and i got the broke bolts out and put new grade 8 bolts with locker washers and loctite. The other 2 bolts were not loose i checked. So i just put back together. Well 3k miles later it did it again the other stock bolt was only one bolt so i took apart again and fixed the bolt and when a head and did the other stock bolt while i was at it. So it had all new 4 grade 8 bolts with lock washers and red LT. Then i drove for a few months and went from here to florida for one of my best friends was kit and kill by drunk driver. Well while i was down there after a few donuts and burnouts for him i herd a pop again and one of my bolt backed out and broke WTF! So i tac weld them and left the one bolt out just to get the car back home. What sucks is this was the only time some metal got into some gears and took some teeth off the spider gears.
1st time and i had it re welded.
Missing bolts. I found the 2 bolts
THe loose ring gear bolts
#8055
alright guys, got the car cranked and got it ldling like a champ thanks to Greg McBride. Now don't criticize yet because I haven't cleaned the engine bay up yet. I just pulled it off jack stands 10 minutes ago. It's a head/cam/intake TA with a vertical radiator mount.
