shreveport/bossier hang out!
#8589
he had a single 88 but didnt like the lag some put twin 67's on it!
http://www.streetfire.net/video/case...7s_2082785.htm
#8594
An 11.5 slick is pretty close. Not sure how much wider you can go but I'm thinking anything around a 12.5 or wider your gonna need to tub it. Don't forget about tire growth either. Most DOT and slicks are gonna grow (swell) the faster you go so you have to be careful of that also or youll cut a tire which could turn bad. I know for a fact you can run 28x11.5x15 without tubbing and it'll hold what your throwing at it with ease. The only thing is your gonna need adjustable lca's to run them on a camaro if you don't want it rubbing the rear bumper. The wheel wells are slightly larger on the T/A's. If your lowered then you can plan on rolling the fenders also.
#8595
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#8599
I can't wait to pull my motor. Im going to go to town under my hood. Going to paint everything Matt/satin black, may remove ac and smooth fire wall also going to remove abs and hide all the lines.
