New Orleans Put the greasy talk here...PiMp
shreveport/bossier hang out!
Old 09-14-2011, 01:06 PM
  #13121
Cold06's Avatar
Good deal! Looks good!
Old 09-14-2011, 03:21 PM
  #13122
AndyIsLost's Avatar
If anyone wants to sell some used 275/50r15 drag radials or normal street tires hook me up
Old 09-14-2011, 03:43 PM
  #13123
Cold06's Avatar
I smell a broken 10 bolt soon.....
Old 09-14-2011, 04:02 PM
  #13124
AndyIsLost's Avatar
I might be safe with the stock gears. didnt break it when I ran bfg drag radials though and the stock clutch actually grabbed...knock on wood!
Old 09-14-2011, 04:06 PM
  #13125
Swerve7rpm2000's Avatar
Originally Posted by mconway68w
Mine launches fine. It's the top half of first that I break loose
Leave on 15 lbs of boost!
Old 09-14-2011, 05:21 PM
  #13126
blue98Z's Avatar
Default Stumped
Ok so I took my coil packs off the other day to paint them cause they were looking kinda crappy. Well I pulled the wiring out and coils and set them aside so just like they came off so they wouldn't get crossed up. Did that once before and learned from the mistake. Put all new NGK's and MSD wires on, plugged in the harnesses and go to fire it up and the car wont start. Went back and double checked everything and it fired up but was missing it's *** off.
Next, I pulled all plugs and the drivers side was clean like they never fired and the passenger side was black and sooty which led me to believe the ECM compensated some how and dumped tons of fuel into that bank. Thinking I somehow criss crossed the coil wiring, I flipped both sides and the car started popping terribly so I new that the way I had it was right, but something went wrong some where.
Any ideas? This shouldn't have happened since it's basically a plug swap that I've done several times over the past 5yrs I've owned the car and countless other vehicles. Kinda frustrated at the moment and wanted get some outside feedback.
Has anyone ever experienced just a bad harness? The whole driver's side bank is dead. That's really odd.
Old 09-14-2011, 06:01 PM
  #13127
SIC LSX's Avatar
On street tires it will be worse at the track then on the street. Ask Andy. He is just a bolt on m6 car and he spun all the way down the track. On street he is fine.
Old 09-14-2011, 06:38 PM
  #13128
Anyone in town running a 4l80e tranny? i have some good componets for sale, transbrake, converter, and a deep pan
Old 09-14-2011, 07:17 PM
  #13129
Cold06's Avatar
What did you go with Ryan?
Old 09-14-2011, 07:20 PM
  #13130
Cold06's Avatar
Josh is it throwing codes? Are the plugs gaped right? Are you sure everything is plugged in, did you disconnect the battery before you unplugged the coils? Try and disconnect the battery for a lil wile (15-30mins) and see if that helps
Old 09-14-2011, 07:47 PM
  #13131
Im gonna go TH400, and josh had a blown injector fuse... I figured with a 3.42 gear and a 30" tall tire i can get down the highway ok still and be 115lbs lighter
Old 09-14-2011, 07:57 PM
  #13132
Cold06's Avatar
I tae it he forgot to undo the ground off the battery before he started, thats good it was a .50 fix
Old 09-14-2011, 08:18 PM
  #13133
blue98Z's Avatar
Yeah luckily it was just a blown fuse. Took her out to "clean" the plugs off
Old 09-14-2011, 08:27 PM
  #13134
Cold06's Avatar
Old 09-14-2011, 09:20 PM
  #13135
mconway68w's Avatar
How do you think some 275/40/17 MT ET Streets would do on my current rims? Can't afford to go all out on rims and tires yet.
Old 09-14-2011, 09:29 PM
  #13136
Cold06's Avatar
They will be great, but you daily drive your car and drag radials + rain = bad. Plus the MT's only last about 5k miles, Nittos would do well also and last 20k mi. Im gonna put some hoosiers on the 15's and NT05R on my 18's
Old 09-14-2011, 09:32 PM
  #13137
blue98Z's Avatar
What kind of wheels? I agree on the nittos for an everyday dr. They will give you more mileage for your money. If your running a 9" wheel you can get away with a 315 nitto in a 17". They run a little thinner than all the other 315's.
Old 09-15-2011, 03:23 AM
  #13138
SIC LSX's Avatar
What josh said.
Old 09-15-2011, 05:55 AM
  #13139
mconway68w's Avatar
315/??/17 ? My rims are 17x9.
Old 09-15-2011, 06:14 AM
  #13140
Cold06's Avatar
315/35r17
Quick Reply: shreveport/bossier hang out!
