shreveport/bossier hang out!
Wade,
I CAN COME TO YOU THIS WEEKEND, NO PROBLEM. Just give me yell or text to schedule it. I would put the 295 on the 11" rim no problem As you said, if 295 hooks why go to 325 (other than appearance).
I would put a cutout on the exhaust like Chris said. You will be unhappy with the exhaust if you run dumps (all the time), and it's not worth getting under the tbss to remove exhaust when only at the track either. Put on a cutout and call it good.
Just my .02
Just my .02
small but will work. Your rear wheels he said were 15x8 http://texarkana.craigslist.org/pts/2570411957.html
I've got a 3:42 rear end and a 3:73 ring and pinion. Just haven't had time to mess with it. I've got to make sure the wheels fit my truck before I jump on some tires.
He said they were 5" bs. A s10 needs 4.5.
Cody, you need studs or lug nuts? I got my lug nuts at patc I believe. They were around $70 for 20 nuts and 20 washers. There open end though and if you have stock studs the track will give you hell because the stud don't stick out past the lug nut.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
ill take the mufflers incase i go twin turbos with 3" downpipes :] are they all rusted up? I figured my full spool would be a pita but ive had pretty good sucess with it but if i did drive it on a regular basis id go detriot locker...
