Lingenfelter Billet Steel Flywheel for ZR1 Twin Disc Clutch 8 Bolt LSA, LSX Engines
The 8 bolt flange Lingenfelter billet steel flywheel is designed to be used on the GM LSA or CTS-V supercharged engine or GM LSx crate engines with 8 bolt crankshaft flanges. The Lingenfelter 8 bolt flange flywheel is an OEM spec billet steel design made in the USA that will accept the stock 2009 - 2010 C6 ZR1 twin disc pressure plate assembly and standard clutch discs. This clutch system will allow excellent street drivability and good clutch pedal feel while still offering exceptional power holding capacity. The LPE billet steel flywheel utilizes the factory locating pins to positively locate the pressure plate on the flywheel. When used in a 2010 Camaro SS the you will also need the Lingenfelter slave/actuator spacer part number L360031410.
![](http://www.lingenfelter.com/Forum/DSCN1267_900.jpg)
The Lingenfelter flywheel is offered by itself or in a kit with pressure plate, twin clutch
8 bolt flywheels should be available around the second week of May, 2010. Picture shown is our six bolt design.
Click --> here to go to store to order flywheel
