Nick @ HSW pls help?
Old Oct 27, 2008 | 10:44 AM
allmotor's Avatar
Default Nick @ HSW pls help?
I have one of your ashtray switch panels, and the lights always stay on no matter if the switch is tricked or not I'd rather the lights come on when i flip the switches, it would make things much easier to me. any help would be great, Thanks
Old Oct 27, 2008 | 10:55 AM
Nick@HSW's Avatar
How do you have it wired? Are you sure the pins are going to the right post? Easiest way to get support is here: http://www.harrisspeedworks.com/support/
We can attach diagrams and a bunch of other documents a lot quicker than via a chat forum. Thanks.
Nick
Old Oct 27, 2008 | 11:05 AM
allmotor's Avatar
I can take pics during lunch. I tried changing the wires around on the posts but it didn't work. I'll get on there or email you some pics
Old Oct 27, 2008 | 11:06 AM
Nick@HSW's Avatar
Sounds good! Thanks.
Nick
Old Oct 27, 2008 | 03:27 PM
allmotor's Avatar
I've tried switching the wires around but they lights on the switches always stay lit.
Red= power
Black= ground
colors correspond to component
only using nitrous, purge, and acc.2 switches. acc1 is disconnected.
Old Oct 27, 2008 | 03:52 PM
bad6as's Avatar
a is your switched 12v
b is your acc
c is your ground
Old Oct 27, 2008 | 03:54 PM
allmotor's Avatar
Red= power
Black= ground
Old Oct 27, 2008 | 04:52 PM
allmotor's Avatar
b is your acc
c is your ground
Ok, are your a/b/c corresponding to how they are in my pic top to bottom? keep in mind the switches are upside down in that pic
Old Oct 27, 2008 | 04:53 PM
bad6as's Avatar
the prings should have a abc or 123
Old Oct 27, 2008 | 04:56 PM
allmotor's Avatar
kthx.
I'll go try in a minute
Old Oct 27, 2008 | 05:05 PM
Nick@HSW's Avatar
Looking at the instructions compared to your picture, switch the 1 & 2 around. IE it looks like you have the acc. wire hooked up to where the 12+ wire should go. Let me know what you come up with. I'll try and check up here when I get home after dinner. Thanks.
Nick
Old Oct 27, 2008 | 07:19 PM
allmotor's Avatar
Yeah they are fine now. They worked before just the light was on all the time. I probably should have read the instructions lol. At least now it's how I wanted it. thanks bad6as and nick
Old Oct 28, 2008 | 02:55 PM
Nick@HSW's Avatar
No problem! Let me know if you stumble across any more issues. Thanks!
Nick
Old Oct 28, 2008 | 03:00 PM
allmotor's Avatar
Nick
Great product btw
Old Oct 29, 2008 | 09:43 AM
Nick@HSW's Avatar
Great product btw
Thanks!
Nick
Old Oct 29, 2008 | 09:45 AM
allmotor's Avatar
The way I have It wired is Acc2 turns on my water pump+ fan, Nitrous arms WOT and turns on dedicated race tank pump. Heater and acc1 are free for expansion.
