NXL... WOT or TPS?
here's a video of the purge
http://centralfloridastreetcars.com/videos/003.MOV
THe NOS sytle nozzle can block injector flow if you are not careful. The NX and I am sure the NOS under the injecor nozzle pulls a 3lb vacumme on the injector which can create a tunning nightmare with larger injectors..
The NX NXL kit is really cool looking and works well on smaller shots and will work well if you have enough fuel system on larger shots with a motor that can take it. The problem is that the motor and directport are feed off the same rails. IN some cases this creates a huge lean spike and the accumulater is only a band aid fix.
You could invest in something like dual intank pumps and it should help.
If you are set on under the injector nozzles NX offers a universal NXK that is just like a real directport but comes with the NXL nozzles..
For the huge difference in cost between the regular nozzles and NXK nozzles you could pay to have a real directport plumbed on your intake.
If I can help in any way let me know. I will help you do it right the first time and save money.
Dave
