Stand alone pump
Old Nov 22, 2008 | 04:17 PM
badaSS346's Avatar
Default Stand alone pump
How much psi does a stand alone fuel system need for a 150-250 shot. (150 on current motor and 250 after build but only want to buy 1 pump)?
Old Nov 22, 2008 | 06:27 PM
Nick@HSW's Avatar
You can run whatever psi you'd like to. Just make sure the pump is capable of flowing the volume of fuel you require.
Nick
Old Nov 22, 2008 | 07:11 PM
TurboAv's Avatar
I called Nitro Dave's the other day and was discussing stand alones and he said for direct port stuff a lower pressure system is easier to tune. Not sure about a plate system though.
Old Nov 22, 2008 | 07:35 PM
Nick@HSW's Avatar
Which plate?
Nick
Old Nov 23, 2008 | 12:10 AM
TurboAv's Avatar
Originally Posted by Nick@HSW
Which plate?
Nick
I was just saying that I don't know if lower pressure is easier to tune on a plate since we were discussing direct port systems and not plates.
Old Nov 23, 2008 | 10:54 AM
Nick@HSW's Avatar
Gotcha, feel free to shoot me over a PM if you'd like to discuss any options etc. Thanks.
Nick
Old Nov 23, 2008 | 06:05 PM
badaSS346's Avatar
Nick
how does one figure that out?
Old Nov 24, 2008 | 10:11 AM
Chris@NitroDaves
Guest
Posts: n/a
You can tune the plate with low pressure just as you can with a direct port.
-Chris
Old Nov 24, 2008 | 11:43 AM
TurboAv's Avatar
-Chris
What makes low pressure easier to tune?
Old Nov 24, 2008 | 11:52 AM
badaSS346's Avatar
So for say a 250 shot...what does the pump have to flow....50...100...150 gph?
Old Nov 24, 2008 | 12:22 PM
Nick@HSW's Avatar
Multiply HP by brake specific fuel consumption value of .6. Convert to gph by multiplying by .26. Use .6 as your value as you can never have enough pump.
Nick
Old Nov 24, 2008 | 12:24 PM
Nick@HSW's Avatar
Jet selection and flow. Think of it this way, how is 1 jet size going to react to 60psi versus 6.
Nick
Old Nov 24, 2008 | 12:41 PM
badaSS346's Avatar
Nick
ok so 250*.6=150
150*.26=39
So i need a pump that flows at least 39 gph?
That sounds way to low.
The way I figured it out is that if for 600 rwhp you need 255 gph and 250 hp is 42% of 600...then you will need 42% of 255 which is 107 gph.
Old Nov 24, 2008 | 01:39 PM
Nick@HSW's Avatar
Take into consideration that you didn't convert 255lph to gph. So using your math you would take 42% of a pump that flows 66.3gph (255lph pump). That comes out to roughly 28gph. I would take a harder look at the bsfc calculation rather than using a percentage rational. And keep in mind that the walbro pumps aren't all the same and most of them are a little deceiving in the actual amount that they flow.
Nick
Old Nov 24, 2008 | 06:10 PM
5_02ls1's Avatar
I use a holley blue pemp....and have seen many others here use the same
Old Nov 26, 2008 | 04:50 PM
Nick@HSW's Avatar
Yup, quite a few people use the Holley Blue pumps.
Nick
