150 dry shot ok on LT1?
I had stock injectors, Just an inline boost pump from ZEX with a 125 shot. Never had problem. Now i have a wet kit, Same stock injectors with same boost pump. 150 shot and still right on the money every time
Better safe then sorry.. Plus you will be set up for any future additions..
Like a 175 shot.. LOL
Nick
Guest
Posts: n/a
Yes it is suggested to replace the pump and injectors if you are going with a dry kit.....but the big issue is how are you handling the fuel enrichment?
I don't like using a huge increase in fuel pressure to force more fuel flow through the injector. 125 or so is about the limit most guys are doing with this style dry kit. I would convert to a wet kit for the LTx platform.
Guest
Posts: n/a
I also said I don't like running a dry kit that relies on increasing fuel pressure for the fuel enrichment.
