Fuel Requirement of Huge Shots!!
I just have the 340 intank and was told that it will be ok till I get over 600+rwhp.
the 340 intank is probably good to 550 safely, and inline in there too maybe 600plus.
but we dont run 90 psi.....with 2 pumps mine idles at 64 and down the track i see 61.
I have the Racetronix set-up now.
The Racetronix single '98 LS1 pump will safely support 550RWHP @ 400KPa / 58PSI / LS1 factory FP. Depending on your BSFC and A/F required we have seen this number as high as 650RWHP. If you require more HP support you can add a pump booster to the Racetronix harness as it is set up for it out of the box! All you have to do is install the supplied connector for the booster and plug it into the connectors provided on the harness. It does not get much simpler than this. With the booster you can safely support 650RWHP+ when running the pump at 16V. DO NOT RUN IT HIGHER THAN 16V as the pump will start to cavitate.
Jack
Racetronix
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
from looking at several charts at that site it looks to me like that chart is based on 12volts, if you run a fat wire to the pump and get the full 14.2 volts it will pump more.
