What else do I need?
Old Dec 16, 2008 | 11:00 PM
blubox's Avatar
Default What else do I need?
Hey guys, I've been reading through the NOS and pretty much know what I need for a safe system.
I'm only looking to use the 100 pills. Do you guys think this is a safe system or what else do I need?
*Wot switch
*FPS switch
*MSD digital window switch
*10 lb bottle
*bottle warmer
I could probly get by with stock fuel pump and timing aggreed. Maybe some NGK tr6s?
Old Dec 16, 2008 | 11:02 PM
jetlag's Avatar
HSW wet plate kit
HSW All-Out accessory package
10% discount code - holiday
DONE! Everything you need...plugs, warmer, window switches, etc, etc, etc,
Old Dec 17, 2008 | 06:07 AM
Mike@HSW's Avatar
Agreed, no timing needs to be pulled and you should be fine on the stock fuel pump. As Jetlag mentioned above our All Out Accessory Kit will include everything you need to have a safe and consistent kit. here is a list of everything that is included. Price right now with the discount will be $359!!
HSW MicroEdge Nitrous Controller
Nitrous Bottle Heater Kit
Nitrous Purge Kit
Nitrous Oxide Bottle Blow Down Tube Kit
Billet Nitrous Filter Kit
NGK TR6 Spark Plug
Old Dec 17, 2008 | 06:49 AM
NVR_SPDS's Avatar
Yeah, check out their accessory kit. I just ordered a Microedge. You wont need a wot switch(It uses a TPS signal), FPSS(Has a rich/lean shutdown and on the rich side, the FPSS wont help), or MSD digital window switch(Its a dual stage window switch).
Old Dec 17, 2008 | 10:34 AM
blubox's Avatar
Nitrous Purge Kit
NGK TR6 Spark Plug
I bought a used kit. It has a NX wet plate. I think the only other accessories I would need is the Nitrous Purge kit NO bottle blow down tube kit, billet nitrous filter kit and TR6s. Do I have to buy the whole kit to get that stuff at a good deal or could I buy it seperate? Maybe it would be best to buy the kit then sell the brand new controller/ bottle heater?
Old Dec 17, 2008 | 10:47 AM
Mike@HSW's Avatar
You could buy them all seperate, but you are correct you would be best off buying the whole kit.
Old Dec 17, 2008 | 12:20 PM
blubox's Avatar
Ok, correction to post #5. The kit I bought is the MAF kit. I thought it hooked up to the TB, but it doesn't.
Old Dec 17, 2008 | 12:42 PM
Mike@HSW's Avatar
That is correct, i was kind of confused when you said NX plate kit
Old Dec 17, 2008 | 12:53 PM
blubox's Avatar
Yes sir, yes sir. Well I pretty much blew my wad and have to pay $500 for a tune once I get the NX on. I will be looking for your dailly Christmas specials though. So basically if I come accross what I need I'll take it outta the rent money and cross my fingers for more jobs, lol. I build fence and this month slowed down because people are spending all their money on Christmas gifts!
Old Dec 17, 2008 | 05:50 PM
jetlag's Avatar
Or go dry kit with the Interface and don't get a tune..haha that's what I did
Old Dec 17, 2008 | 06:02 PM
blubox's Avatar
Well I already bought the kit...So i'll just have to roll with it. I got a good deal and I think it will work out good, just cost an extraa 500 for the tune. I was gonna get a tunr anyways though. Because havn't tuned since LTs and LS6 intake.
