Effects of Progressive Controller on solenoids?
I was told that a progressive control can cause solenoids to leak? Is this true? The reason being a progressive pulses the solenoids when your at say 75% and it will beat the seats out in the solenoids causing a leak?
Its puts ALOT of wear and tear on the solenoid. A while seasons worth of abuse can be done in one pass. If you have never taken one apart search for a few pictures and you will understand. It beats the **** out of the rubber seal in the noid.
Well I have a chance to get some NX Solenoids for a decent price, but they were ran on a progressive controller. He dont want to much, and says nothing wrong with them, but whats the chance they leak or the seat is messed up from the controller.. Im not sure what to do, I buy them and they need rebuilt, depending on how much to fix them, I may be better off buying new ones..
its limited lifetime for the "lightning series solenoids" to the original purchaser. These are the model before that, the big ones. Those only have 90 days to the original purchaser.
I would replace the coils also. NX solenoids, the biggies are known for big amp pull and this also lessons life. So if they were progressed, I would just pass on them unless it's still a deal to rebuild and replace coils, that's my opinion. Why chance a motor on someone else's used up stuff, though only you can make the ultimate choice.
Robert
Robert
Closed ex-Sponsor Account
The piston material will differ from one company to the next. NX uses or did use a double spring compensating piston. There is a tiny spring under the sealing material, allowing it to seal at lower pressure. Over time the piston will develop a dimple, and it will get larger (deeped) over time of use. This dimple will allow the piston to set lower and lower on the seat, till finally the piston is no longer in the magnets pulling field area.
If you have to replace coil becuase they failed, you might as well as get a new solenoid and use your old ones parts for back ups.
Solenoids arent what they used to be and they are made much stronger then the early years of say the NOS noids that did fail due to progressive systems. People shouldnt worry about solenoids failing anymore becuase its pretty unlikley to happen.
Any sponsors care to comment on this? I was kind of curious about noid life in general, not just ones on progressive setups. ive had mine about 2 years without taking them apart. maybe its time to do so.
Guest
Posts: n/a
The current set of solenoids on my car have been on there since 2002...they have been used with a progressive the last 2 seasons. At the last inspection they still looked OK.
The Nitrous Outlet solenoids are built to be used with a progressive. We have yet to see a solenoid fail because of one.
