150 Wet Shot ok?
Old Sep 30, 2003 | 11:45 PM
LS1Formula98's Avatar
Default 150 Wet Shot ok?
I am gonna go Dyno this weekend, and wanted to make sure I was safe with running a 150 wet shot.I have mostly bolt ons. Anyone else run a 150 wet on dyno? Results? TIA
Old Sep 30, 2003 | 11:50 PM
TransAm2002's Avatar
Default Re: 150 Wet Shot ok?
I run a TNT 150. As long as you have a good fuel pump and good gas you should be fine. Colder spark plugs are must as well.
Old Oct 1, 2003 | 12:00 AM
Well, Its a stock fuel pump and I use 93 octane. Are you saying I need a better pump or just make sure mine works properly? Also, I am running TR-6 plugs.
Old Oct 1, 2003 | 02:38 AM
Black02SS's Avatar
Watch out if you are using a TNT kit. I jeted for a 100 and got a 150.
Old Oct 1, 2003 | 07:55 AM
Its a NX kit.
Old Oct 2, 2003 | 11:15 AM
bigSS's Avatar
I'm not sure i'd use a 150shot, with stock timing, and 93 octane. I think you'll get detonation like that. I've been told to either run some race gas or retard the timing for that large of a shot.
Old Oct 2, 2003 | 04:27 PM
WICKED SS's Avatar
Start out slow
75 shot, then 100, and then if everything looks good go for the 150. Thats what the dyno is there for to tune your car a/f so I would. But I only would if you run race gas. I see people on here running 100-150 on top of heads and cam so if you only have bolt ons you should be ok with tuning and race gas.
Old Oct 2, 2003 | 04:48 PM
Well, I have never used race gas. Do i just drop a bottle of some octane boost or is there actually a place that sells high octane out of a pump? Sorry if that seems like a dumb question, but I have only seen the octane booster stuff at some of the auto stores. TIA.
Old Oct 3, 2003 | 11:45 AM
WICKED SS's Avatar
Some gas stations have it like 76. Its not those OB bottles from pep boys.
Old Oct 3, 2003 | 12:08 PM
35th SS's Avatar
what hes saying is get an aftermarket pmp. like a walbro 255lph and do the swap before you hit the 150shot.your rolling the dice with the stock pmp.dont do it.
Old Oct 3, 2003 | 02:36 PM
Ed Blown Vert's Avatar
I ran a 150 shot NX on my stock motor for about a year with no issues.
