MS4 , LS6 heads , cometic gaskets
Old Jan 6, 2009 | 06:01 AM
PONTIAC SLP's Avatar
Default MS4 , LS6 heads , cometic gaskets
hi , my buddy have 2002 trans am m6 , he want to install ms4 112 LSA with stock 243LS6 heads and cometic heads gaskets thickness .051 , there will be problems ? can he run with cometics .040 ?
Old Jan 6, 2009 | 06:04 AM
Bonashi-FireBird's Avatar
thanks man for this point i need to now to
Old Jan 6, 2009 | 09:48 AM
Nick@HSW's Avatar
Are you asking for P to V clearance? That's probably a question better answered by TSP in the internal section not the nitrous section. Maybe a mod can move the thread for you.
Nick
Old Jan 8, 2009 | 10:08 AM
vetteboyc5's Avatar
The answer is no to .040.
Im running a MS4, 243s and stock gm MLS gaskets. the Heads will work fine, cam will too. Piston to valve is VERY close assuming a stock .055 compressed gasket is used.
If those 243's have been milled at all, You will have to flycut no getting arround it either.
If they havent and you want this to be at all safe without flycutting, youll need to run a stock gm MLS gasket. they are 40 for both no need for cometics.
Old Jan 8, 2009 | 10:17 AM
thanks a lot , what is your mods ? how many rwhp did u get at the dyno ?
Old Jan 8, 2009 | 10:19 AM
Nick
yes PTV , i was wrong when i wrote this thread here , i did't note that , BTW thanks
Old Jan 11, 2009 | 12:22 PM
evilz's Avatar
awsome i was wondering the same thing
Old Jan 11, 2009 | 02:22 PM
NastyC6's Avatar
Yep, GM head gaskets are the way to go. Never heard of anyone blowin them, i've seen a lot of cometics blown.
