Injectors for c5 z06 150 dry shot
http://fuelinjectorconnection.com/sh...&productId=181
will this be enough? I have a plate kit and HSW interface
I'm making about 380-390 off the bottle im guessing (trapping 118.5)
so im guessing ill be aroun 530 or so on the 150 shot. Will the injectors above (42lb @ 58psi, which is essentially 36lb) be enough fuel at ~80-85% duty cycle?
If not any recommendations for this setup?
Why are you looking at that injector for a C5 z06? Those injectors are C5 style, but have ls2 plug connections on them. Additionally what are your current mods, fuel system, and injectors. I am also wondering are you spraying the 150 wet or dry?
I would suggest some SVO green tops, which are a 42 lb injector rated @ 43.5 psi fuel pressure. They will work great if you ever plan on running a hot heads and cam setup. If you plan on staying fairly stock than you can get away with SVO 30 lb injectors.
You can use either. It all depends on what you want to do later. I would suggest the 42 lb injectors just because it gives you future room to expand the engine later with better heads and a bigger cam.
