NXL install tips
Old Oct 6, 2003 | 09:09 PM
Bad Habit Bird's Avatar
Default NXL install tips
For those of you who will be getting an NXL kit sometime in the near future I figured I would help you out with a few pointers and info I learned while doing the install on my car.
First of all Leave the intake on the car, the directions show the intake off of the car but one you put the rails on you can't put the intake bolts in because they are in the way.
Second, when it comes time to put your injectors in the NXL Fuel rails grease the o-rings up with some wheel bearing grease or motor oil (NX recommends WD-40)
Another thing about putting the injectors in the NX fuel rails, an ice pick with a bend on the end will be VERY usefull, I cut up quite a few of my o-rings before I figured this trick out just get one side of the o-ring/injector in and work the rest of it in using the ice pick (or flat head screwdriver if you are carefull)
Once you have the fuel rails in place and are ready to connect all of the lines start from the back and work your way to the front on each side, connecting the fuel lines to the rails and getting them tight first then do the nitrous lines. (with the nitrous lines connected to the rail it is somewhat difficult to get to the fuel fittings on the rail to tighten them)
When connecting the lines to the nossles if you unbolt the coil packs and push them away from the intake (not disconecting the plug wires) it really gives a lot more room to work with to tighten the fittings.
The wiring harnes has the solenoids and the relay connecting to the same o-fitting so they have a common ground, if you plan on running a window switch you will need to cut the white wire from the relay and run that to the yellow wire on the window switch (applies to MSD switch) the black wire with a white trace (ground for solenoids) needs to have its own ground. If you try to connect them both to the yellow wire you might have problems with the solenoids not staying open.
Another thing to keep in mind is make SURE you have everything VERY clean and put a new fuel filter on the car as well. The jetting for the fuel side is only a # 10 jet which is extremely small and any little bit of trash in the fuel system could get caught in one of the jets if you are not carefull.
Once you have everything connected turn the key on and check for leaks, if there aren't any leaks go ahead and start it up and drive around a little then check for leaks again just to be on the safe side.
To check the solenoids arm the system (without the bottle hooked up) and either you or a buddy hit the WOT switch to see if the solenoids "click". Usually you can feel them but with all of them being built into the rails it is hard to make sure they are all opening so I used a screwdriver and touched the tops of the solenoids to make sure they were all "magnatized" when the WOT switch was on and not when the kit was off.
When checking the solenoids for functionality go ahead and pull the fuse for the fuel pump under the hood so you dont dump fuel into the motor while you are checking them. If there is any fuel left in the lines it will send it straight into the motor and flood it.
If you do for some reason flood the motor let it sit for awhile and try to start it again. You also might want to change the oil if you flooded it too bad.
Ill post up more as it comes to me.
Old Oct 6, 2003 | 09:28 PM
Country Boy's Avatar
Senior Member
Default Re: NXL install tips
PICS!!!!
Old Oct 6, 2003 | 10:58 PM
JF WS6's Avatar
pics! pics! pics!!!!
Old Oct 7, 2003 | 09:43 AM
v8maro's Avatar
PICS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Also, so are you saying if you want to take your intake on/off with this kit, the fuel rails have to come off every time?
thanks
-Steve
Old Oct 7, 2003 | 02:39 PM
I dont have any place to host the Pictures but if someone else does I can email them to you.
You can probably take the intake off with the rails still on the intake because the is enough room for the bolt to come out of the threads in the heads. A ratcheting 8mm wrench would be a VERY handy tool that is for sure.
Old Oct 7, 2003 | 05:53 PM
Senior Member
I can host them on my Webshots. Email them to me.. countryboy@tampabay.rr.com
Old Oct 7, 2003 | 06:52 PM
Louis's Avatar
If not, Send em to me Sean-
lgigliot@purdue.edu
Unlimited Bandwidth
Old Oct 7, 2003 | 07:05 PM
Senior Member
LOL... send them to Louis!
Old Oct 8, 2003 | 10:22 AM
v8maro's Avatar
http://www.ssgraphix.com/cgi-bin/uploader/
Upload them there, my site.
-Steve
Old Oct 8, 2003 | 08:34 PM
BigPlanTransAm's Avatar
thanks for the info. im sure im not the only one who will find it usefull
Old Oct 8, 2003 | 10:35 PM
Louis's Avatar
Update Pics Here!
Old Oct 9, 2003 | 02:34 PM
I added a few things for everyone.
Old Oct 16, 2003 | 09:54 AM
TTT Im sure many of you are starting to recieve the kits and just thought I would bump this up for everyone
Old Oct 16, 2003 | 01:56 PM
TomQ's Avatar
has anyone installed in on a vette? c5/z06?
Old Nov 1, 2003 | 04:02 AM
CAT3's Avatar
Restricted User
ttt--
Old Nov 2, 2003 | 11:31 AM
CAT3's Avatar
Restricted User
Hmm, odd i got no instructions...am just going to go ahead and do this logically.
Old Nov 2, 2003 | 11:56 AM
JF WS6's Avatar
Sorry, I can't remember the post but Brains posted up some digi-cam pictures of the instructions. It is pretty logical though, they mostly help for the last page that has the wiring instructions on it.
Old Nov 2, 2003 | 01:21 PM
CAT3's Avatar
Restricted User
Thanks, going to post the process and ask a few questions before I begin...
