200shot + Stock LS1?
Old Feb 3, 2009 | 10:39 PM
01SOMZ28's Avatar
Originally Posted by matt3383
good thread man. Im just going to be stepping up to a 150 shot myself... i hope it will keep me happy for awhile haha... doesnt sound like it will from this topic haha.
dont get me wrong a 150 shot is plenty! I'm still happy with how my car performs with the 150 and i'm sure you'll love it as well. But i'm just to used to it now and i need more! haha this 200shot isnt a 100% decision for me, thats why i started this thread so i could get some input from other guys that are doing it on a stock LS1 and how they like it. I'm installing a cam here pretty soon so i'll see how i like the 150 combined with the cam before i make my decision to go bigger.
Old Feb 3, 2009 | 10:44 PM
ballerchris510's Avatar
Originally Posted by 1 QUIK LS1
Yes 200 shot and i've only changed the plugs once in that time...As said in some of the above post a good fuel system a MUST.
Just curious what gas do you put in the standalone and what jets sizes are you runnin for that 200?
Old Feb 3, 2009 | 11:38 PM
krazy4's Avatar
Probably at least 100 octane. I would run C16 in the cell if I had a standalone.
The nitrous jet for a 200 shot would be around a 0.072. The fuel jet should be figured out accordingly on a dyno or by reading the plugs.
Old Feb 4, 2009 | 07:58 AM
382ssz28's Avatar
I ran 150HP for 3 years. Stock bottom end with rod bolts. 346 with heads, cam and intake, with 36lb inj. 3-5 bottles a week, (I'm a sick F---!). The last 3 races I went to I threw 200 at it. It only picked up a couple of tenths as we found not the fuel, but the factory SS ehaust held me back, finally spinning #6 rod bearing. I had 1 3/4" Dynatech hedders with their 3" y-pipe and high flow cats. I have the Walbro 255 with the Casper Elec. wire. I think if it was ramped up or staged and the exhaust issue was addressed, it's possible the motor would last longer. 200HP is alot off the line all the time.
Old Feb 4, 2009 | 02:24 PM
1 QUIK LS1's Avatar
I run 110 octane in the stand alone and i run 2 nozzles,100 shot on each.The universle E.F.I. NOS kit nozzles are only good to a 150 shot(140 realisticly lol).Because of the stand alone system i run(its a lil different than most) i run a square jet pattern on my set up, been that way for 4 yrs. now and seems to work pretty good.On the 200 shot(100 on each nozzle)i run a square jet of 47 NO2 and 47 on the fuel.
Old Feb 4, 2009 | 03:46 PM
matt3383's Avatar
I am running 100 octane with my 100 shot now as it is... cheap insurance really.
Old Feb 5, 2009 | 12:47 PM
nevrlift13's Avatar
Originally Posted by 02SS:ZEUS
My LS1 has about 80k miles on it. The heads have never been off the car, nor the oil pan. I spray 150 religiously. And have recently been spraying 200 through it. I've got a Nitro Daves stand alone with 108 in it and a Nitro Daves plate. Everything works great, and I've yet to have any issues at all. When I went to the 200 shot, I went from TR6's to Autolites version of the TR8's, which is actually a half step colder than the TR8's. I also pulled a little more timing. How long will it last????? I dunno. We'll find out.
is that a 108 leaded fuel? how does it affect the O2's if so it is leaded fuel..?
Old Feb 5, 2009 | 05:26 PM
02SS:ZEUS's Avatar
Leaded. I've been through a few O2 sensors, but it's cool....I only payed for two. You get 2 new ones from Autozone the first time one goes out on ya.....they have a 12 month warantee. As long as you use enough nitrous, one of them is gonna die again before that 12 months is up. That vicious cycle will continue, and you will continue to get them replaced for free from Autozone. I also completely gutted my high flow cats with the use of nitrous and leaded fuel.
Old Feb 6, 2009 | 06:10 AM
Justins00ss's Avatar
Just curious as to what you mean by a square jet pattern?? I also run a dual nozzle wet setup with N.O.S nozzles and would like to step it up to a 200.
Old Feb 11, 2009 | 09:46 PM
01SOMZ28's Avatar
Old Feb 16, 2009 | 12:06 AM
rmata's Avatar
I've been spraying a 150 shot for years on a heads/cam car with stock bottom end. Been debating a lot whether to try out the 200 pills. This year just might be the year, lol
Old Feb 16, 2009 | 04:19 PM
  #32
bad6as's Avatar
i got my car stock at 74k added at cam at 98k then spray at 100k. i use the hsw dry plate used the dual .44 jets for 5 or so bottles. now i use dual .48 jets havent sprayed them yet
Old Feb 17, 2009 | 07:57 AM
  #33
1 QUIK LS1's Avatar
Square jet pattern= 47 fuel and 47 on N20.
