200shot + Stock LS1?
Old Feb 1, 2009 | 07:00 PM
01SOMZ28's Avatar
Default 200shot + Stock LS1?
I've been running a 150shot for almost a year now and have had absolutely no problems. I've been trying to do some research but i'm not quite finding what i'm looking for. I'm looking for some info an thoughts from some people that know what they're talking about. Will a stock internal LS1 handle a 200shot?
Old Feb 1, 2009 | 07:03 PM
Captain_Stabbin's Avatar
im sure it will, but not for very long, i would just build it, that way you wouldn't have to worry about it,
Old Feb 1, 2009 | 08:57 PM
Mike@HSW's Avatar
the stock bottom end can handle it, thats usually not the problem. When you step up to that size you need to do some upgrading to your fuel system. First would be upgrading your stock fuel pump to something like the walbro and hotwire kit. Other probelms you will have are volume issues. With a dedicated fuel cell you wont have any problems at all. A lot of people have problems running a 200 shot off the stock rails. It is possible to run that size shot, you just need to be aware of the risks. I would also recommend colder plugs, better fuel and pull plenty of timing
Old Feb 1, 2009 | 09:24 PM
01SOMZ28's Avatar
^i'm currently running TR6's for plugs and next on my list for mods was going to be a walbro, injectors, rails, fast 90/90 and MS3 cam. Besides the cam and intake, is that going to be good enough for supporting mods? along with a spot on tune.
Old Feb 2, 2009 | 06:57 AM
02SS:ZEUS's Avatar
My LS1 has about 80k miles on it. The heads have never been off the car, nor the oil pan. I spray 150 religiously. And have recently been spraying 200 through it. I've got a Nitro Daves stand alone with 108 in it and a Nitro Daves plate. Everything works great, and I've yet to have any issues at all. When I went to the 200 shot, I went from TR6's to Autolites version of the TR8's, which is actually a half step colder than the TR8's. I also pulled a little more timing. How long will it last????? I dunno. We'll find out.
Old Feb 2, 2009 | 10:32 AM
LSXFORMULA99's Avatar
my buddie has been running a 225 shot for a while now and he is fine...i think he has 35lb injectors and 255 fuel pump. and the car has 175k miles. with stock 10 bolt he runs 10.6
he says its all in the tune. lol
Old Feb 2, 2009 | 11:24 AM
02SS:ZEUS's Avatar
FYI, you generally don't need bigger fuel injectors for a wet shot. Just a bigger fuel pump, or a stand alone w/ it's own fuel pump.
Old Feb 2, 2009 | 01:37 PM
jmill96Z's Avatar
That's what I was always worried about when I ran 200 off the rail, and was a factor in me deciding to go 2 stage. I know the 255 can handle the volume of the shot, but was worried about the sudden draw starving the rails.
Old Feb 2, 2009 | 02:11 PM
blwn_00gt's Avatar
so are you on the stock fuel pump right now?
Old Feb 2, 2009 | 04:19 PM
01SOMZ28's Avatar
yes...for now.
Old Feb 2, 2009 | 05:53 PM
ballerchris510's Avatar
when you tuned it on the 150 what was afr just wondering.... also what are your nitrous/fuel jet sizes?? a 200 is doable but i would only do it with a standalone with TR8's and maybe spray it no lower than 3500rpm...
Old Feb 2, 2009 | 06:50 PM
blwn_00gt's Avatar
yes...for now.
awsome...
Old Feb 2, 2009 | 07:24 PM
01SOMZ28's Avatar
i cant remember what the afr's were, i'll have to find my dyno sheets and look because i know everything was printed off. Also i'd have to look at the jet sizes cuz i dont know off the top of my head.
Old Feb 2, 2009 | 08:35 PM
1 QUIK LS1's Avatar
All stock except cam and bolt on's,Stand alone,TR6's,LS1 Timeing tuner with 7 deg. pulled,cuts on at 3000 off at 6200.Been this way for bout a yr. now.Car has 84,000 on it.Knock on wood lol lol.
Old Feb 2, 2009 | 08:58 PM
Quick Sh0t xMLx's Avatar
That's on a 200 shot?
Old Feb 2, 2009 | 11:16 PM
01SOMZ28's Avatar
^ thats what i was gonna ask
Old Feb 3, 2009 | 02:17 PM
krazy4's Avatar
You need to have a great fuel setup to do it properly.
Nitrous needs fuel and a lot of it.
I say a standalone fuel system and one step colder than TR6 plugs would be ok.
I could see a 200 shot with a standalone and COLD plugs lasting a long time.
Old Feb 3, 2009 | 02:52 PM
matt3383's Avatar
good thread man. Im just going to be stepping up to a 150 shot myself... i hope it will keep me happy for awhile haha... doesnt sound like it will from this topic haha.
Old Feb 3, 2009 | 07:49 PM
1 QUIK LS1's Avatar
Yes 200 shot and i've only changed the plugs once in that time...As said in some of the above post a good fuel system a MUST.
Old Feb 3, 2009 | 10:20 PM
SSmoken's Avatar
you guys have some ***** !!! thats awesome. i have 128k on mine so i probably would want to. Ive yet to make a pass on a 150 shot so we'll see how that goes for me.
