Nitrous Accumulator
Old Feb 16, 2009 | 06:27 PM
Juicedz28's Avatar
Default Nitrous Accumulator
How many of you run an accumulator in conjuction with a fpss as another safety percaution?
Old Feb 16, 2009 | 09:26 PM
myfast70's Avatar
If you need one, shoot me a pm and I'll make you a smoking deal on one.
Old Feb 16, 2009 | 11:39 PM
Nitro Dave's Nitrous Outlet's Avatar
What type of Set up are you running? What is the reason you feel you need a Fuel accumulator?
Dave
Old Feb 17, 2009 | 11:07 AM
Nick@HSW's Avatar
I wouldn't advise using an accumulator as a band-aid type fix. I would address the problem you're seeing first hand with a pump/front mount regulator/etc.
Nick
Old Feb 17, 2009 | 05:12 PM
Juicedz28's Avatar
I was told that the accumulator will help eliminate the lean spike of the initial hit. I'll be running a wet plate kit from Nos.5168 i believe.
Old Feb 17, 2009 | 10:51 PM
I am not afan of the accumulater. If you are having a lean spike due to fuel pressure drop its time to upgrade the fuel system. If you are having a lean spike and the fuel system is not droping pressure the fix would be to shorten the hose from the fuel solenoid to the plate.
Let me know if I can offer any technical help.
Dave
Old Feb 18, 2009 | 05:15 AM
Nick@HSW's Avatar
Another way around it is to use a controller like the microEDGE to add a delay to one of the solenoids. Inherently the F-Body fuel system has its demons and occasionally there is the one car that shows this issue more than the others. I would get everything together first and go from there. No point in spending money where it might not be needed. Just my $.02.
Nick
Old Feb 18, 2009 | 05:26 PM
Juicedz28's Avatar
Thanks alot for the replys. Good info. I'll put it together and put it on the dyno and go from there. Thanks alot.
Old Feb 19, 2009 | 10:32 AM
Nick@HSW's Avatar
No problem.
Nick
