Should I be scared of ramping up nitrous?
I have a 02 ls1 w/ stock engine, torquer v3 cam, full boltons, 150 wet kit. I have a/f cutoff, rpm window switch, wot switch. I have tuned the car myself with hptuners. I tuned the car myself with hptuners and have it set up to pull timing when spraying. Racetronix fuel kit.
Ive been through three bottles of 75 shots with no problems.
I kinda want to push it higher. Should I be worried or is it fairly safe to do so? Any point where I actually am taking a huge gamble with? I hear a few mixed things.
You should be pleanty safe at 150HP. Pull 6* and creep up if you want to live on the edge. Get plugs a couple of sizes colder. 200HP is a lot all at once and hard without good rod bolts, but the 150HP is fine. I ran 3-5 bottles a week for 3 summers. Now going to try FJO and ramp it up 50-200HP or more as I went to forged setup. Add the NANO and have a blast!
