My first nitrous kit
125 nos wet plate(Im not pretty sure what brand but it will be plate)
NOS progresive louncher
HSW the interface
stand alone fuel system for the kit(need recomendation on what pressure will be fine)
Im driving a stock internals ls1, whit some bolt ons, cam(dont know wich one, the previous owner forget it) headers, stall, transgo an 342 gear.
And I was giving some thought on trowing another stage whit a dry shot since I can get a kit very cheap from a friend of mine, so this way i can get more benefits of the interface and the NOs louncher.
The dry shot I was thinking on put it after maf an use the interface to compensate the mixture and use the safety function of Rich/Lean shot off on the louncher.
Opinios?, pros and cons of putting the second stage
HSW the interface
Thanks.
Nick
The NOS Mini works great... With a wet system there is no need for the interface. Spend that money better somewhere else. If you are wanting dual stages keep it simple and use our dual stage plate system. We are the only company on the market with a dual stage plate.
If I can help you spec out a system or answer any questions please let me know. I will be happy to help.
Dave
With ten discharge points spread across the inside perimeter, there is no plate out there better at distributing the mixture. It works with the incoming air flow rather then against it and fully fogs the intake. It atomizes so well i doubt there is a plate out there that can suspend the fuel for as long as it does. It also flows just about all you would ever need.
There are many options you can go with, if you have any questions at all please dont hesitate to shoot myself or nick a pm.
Nick
Right now I got the stock pump,but im putting a walbro when i star up the hole installation of the nitro,
I want to use the stand alone for safety reasons cuse the fuel around here is kind of bad, I'll be using vp for the cell.
In first time I was just thinking to use only 1 shot of 125, but since i can get a complete dry kit very cheap thats why I add the interface to the kit, to tune the second stage and pull some timing when the shot came in,
I thinkig start whit a 125 wet, and a 50 dry and see how things going and later start to going biger whit the dry shot, maybe a 75 then a 100 hps shot
Or I can get better results whit 2 stage of wet, maybe 125/75 to start?
Nick
Whit the intarface i can pull more than 3 degres whit out pulling timing on the tune, these because the car is DD and im only sprayin at the track maybe 1 or 2 weekend per month.
I can run a safety switch pressure on the stand alone no matter if i go high or low pressure?
