HSW noid going bad
my MAIN concern is the solenoids themselves, im REALLY REALLY concerned about my other noids, as they have not been used frequently, but consistently, and now are failing.
Dave
is it possible your pressure is higher than 1050? when it gets a little warm, my nano setup seems to get the pressure a little higher than i want it to until i relieve some of it.
Dave
Your options are pretty simple. If cost is a factor you could use our Brand X purge solenoid. It is on the lower cost side of things but its actually designed to open under higher bottle pressures compared to other purge solenoids on the market.
Second is our Nitrous Outlet solenoid. They cost alittle more but we use the highest end of everything available. They are also rated and designed for the higher pressures.
Or you could contact Nano and send the system back to have them regulate the system to work at a lower pressure.
Dave
If you dont mind switching brands shoot me a pm on which solenoids you need and I will make a recomendation.
Dave
Nick
Nick
No, I don't trust zip ties as a secure mounting method but I'm glad to hear that you've since mounted them more securely.
Nick
