lsx454 n20
Old Apr 1, 2009 | 09:51 PM
T2SLS1's Avatar
Default lsx454 n20
Whats he largest shot of nitrous I can spay on a lsx 454? with nitrous pistons and a dedicated fuel tank..
Old Apr 2, 2009 | 09:58 AM
z28rob18's Avatar
probably more then any track could hold lol how much you lookin to spray? i wouldnt ever spray more then 500 if i had the equipment to do so but im sure it could handle more
Old Apr 2, 2009 | 10:17 AM
T2SLS1's Avatar
i was going to run between 100-300 shot on my 408 build before the upgrade to lsx454, because of the stoke are there any limitations for that size on nitrous shot?
Old Apr 2, 2009 | 10:22 AM
z28rob18's Avatar
never heard of any as long as you have the parts in the motor forged crank rods and the nitrous pistons you mentioned you'll be alright runnin a 300 shot
Old Apr 2, 2009 | 04:25 PM
ATwelveSec02Z28's Avatar
Lots of things to consider - there are a few things done in a nitrous built engine that might otherwise be different. When you get to levels of 300 or more, it is very important to have things dialed in accurately.
Old Apr 2, 2009 | 08:02 PM
T2SLS1's Avatar
i have been searching I thought I read that some one was saying that a shorter stroke and bore was better for nitrous, and that that large of a stroke would not be good... But just read my GM high tech and Vengance has 2 big bore large stroke cars both running nitrous.. and the black ss was running a 454lsx! just wanted some feed back....
Old Apr 3, 2009 | 11:42 AM
Noyzee's Avatar
8 second mod
you can run between 0 and 1,000,000,000,000,000,000+
depending on parts, set up, tune, how often you want to brake stuff, suspention etc etc etc.
hope this helps.
my wise *** remark is pretty much saying there is no right or wrong answer to this question, and its been asked many many times.
Old Apr 3, 2009 | 11:59 AM
T2SLS1's Avatar
Thanks for the wise *** remark, but i posted in the last reply that I have searched and i only found one responce may be im searching the wrong topic, But i have pretty much decided to just keep the 454 with all the callies, and nitrous pistons and spray it! Thanks for the help!
noyzee one more question why did you chose lsx427 over the 454,or 440?
Old Apr 3, 2009 | 12:11 PM
jmill96Z's Avatar
You can't find **** in the search anymore.
I think I remember reading somewhere that GM suggested anything over a 440 be in N/A applications due to cylinder wall thickness and bore spacing. Any comments?
Old Apr 3, 2009 | 12:17 PM
Ron@Vengeance's Avatar
Search function ROYALLY SUCKS these days...
We are spraying 300 on a 454 we built. It was just featured in GMHTP last month... High 5s in the 1/8 at a pretty stout race weight.
The thing to consider is with the longer stroke the pin is pushed further up into the piston and also the compression height is altered in a bad way... Lots of people dont suggest big power adders on combos like this, but we have absolutely no issues on the combos we have built.
Old Apr 3, 2009 | 12:23 PM
T2SLS1's Avatar
Thanks Ron I just mention that in a earlier post that I read that article and saw Jan on Pinks All out Last night.. Thanks for the info
Old Apr 3, 2009 | 12:31 PM
T2SLS1's Avatar
I would be happy with a 427 making the powers and #s of noyzee! What are bore and stroke of a lsx 427?
Old Apr 3, 2009 | 05:30 PM
blu byu EH's Avatar
4.125 bore and 4.000
Old Apr 6, 2009 | 08:52 AM
Noyzee's Avatar
8 second mod
i went with the 427 for a couple reasons. going 440 or larger screws me up in a local class, if i blow her up and catch the walls, i have meat on there to bore.
if you punch a race block out all the way the first time. you get one shot at a $2,000 block.
with my NA numbers on a car set up to run spray i havent seen many bigger cubes much more impressive. esp if you look at how basic my set up is i have a home ported old style intake, no sheet metal stuff here, i have a nitrous converter and a power glide with 3:73
im thinking this season with the 400 in the car and a little more power from the new heads i'll be in the 9.4- 9.5 range on motor in a car set up to run 300+
that said. i would do a 427 again without question
also, keep in mind i tuned this car with hp tuners and rev it to 8,300 and i have no clue how to tune. lol i bet in the right hands with someone who knows how to tune this car has more in it.
Old Apr 6, 2009 | 08:54 AM
Noyzee's Avatar
8 second mod
ps. i run an eagle crank. basic $500 crank, and ive had it in 2 other motors. lol only thing i have in my car is the best rods i could buy. GRP other then that its pretty basic stuff with stock motor mounts still. lol
