Picked up a Nitrous kit
So i have a 2000 trans am 6spd w/ 410's.Its basically stock.I have a true ram air intakes sys,All the free mods,Hypertech programmer III,ORY,Mufller delete. What is it going to take to safely run a 150 shot???O yeah it only has 79,644 and is not a daily driver it only moces on friday night and saturday nights. lol just a weekend fun toy
As long as the A/f ratio is right you should be ok, but with the nitrous and a 6 speed i'd definitely get a window switch. If you really want to be on the safe side, look into k-tech rod bolts and a high volume/pressure oil pump.
i got mine all set up, it has a FPSS and window switch, but is only jetted for 100. if your not going to upgrade the fuel pump then definately ghet the FPSS, i would anyway though. Its cheap insurance.
Make sure to get some new plugs too.
A tune is not necessary but i would recommend it. But then again i am no expert
So you think i shouldnt run the 150 than until i get the above listed??? Im soo far getting colder plugs and a dyno tune from a local tuner who uses hp latest tuner software.And than i guess im going to look for a window switch i think its called??
You can run the 150 without the listed above, BUT if you want to run it reliably and safely then get all the above. buying rod bolts is cheaper then buying rods, pistons, block, or whatever else may fail. But then again there has been people running 225 shot on a stock ls1. Give 02 blk ws6 a pm. Don't take one persons word for it, get may opinions and make your own decision
Well my tuner said he would hook it up for me and make sure it would be safe.But he is just a car guys and soes all kinds not just ls motors.So thats why im asking just in case
Cool, just check where your timing and Air/fuel is at. I would definitely get a window switch. Check out the HSW Microedge, very nice piece.
http://www.harrisspeedworks.com/shop...age=1&featured
or here is everything you would need:
I agree with Caribe, pick up a Microedge(I have one, going to be installing soon), and a Racetronix plug-n-play fuel pump setup, then look into getting a good tune and you should be good to go.
