what is it about nitrous the makes it break stuff?
80% of the crap you read on this board about nitrous tuning is wrong. I only listen to a select amount of people here now. and am learning as time goes on what i need to do to tune my motor the best. Im doing all the nitrous tuning myself and letting my tuner only mess with the n/a stuff. dont trust anybody but myself around here.
Every setup is different... There is no one size fits all setup! Tune by the plugs. Run the correct plugs! Run the right fuel. You may get away with a bad tune on a baby shot but when you step up to a healthy dose you will burn **** up on a bad tune.
Read this article , this will tell you what im talking about.
http://www.gmhightechperformance.com...ely/index.html
re read your post. first off .035 to .308 is to blanket . 2nd noone needs to oring a block. we hit mine with 550 on a 4 bolt 6.0 block and never pushed an once of water. to much timming is why you push water. the a/f will be between 12.5 and 13.3 if its right or for the most part on an ls1 but thats even to blanket.
your post was garbage period. You have been doing it wrong for 15 years if thats what you do. and lean doesn't burn up stuff to much timming burns up stuff. but what do i know
My wideband has helped me out alot in tuning for N/A (~13.0) , then I just throw in the recommended nozzles and hit the ~12.0 range and pull some timing and call it a day. You follow a few "general" rules and it help you spray safe.
Ive went lean pretty bad one time and thought I got off the gas pretty quick, when I got back and pulled plugs 4 out of the 8 had no ends left.. Im sure if I wouldnt of had the wideband in and saw it when I did it could have went alot worse. So, I dont think your statement of A/F on nitrous is accurate.
I would also imagine your block is built for spray... So, you have a bigger window for error.
Key word being CANT.
I posted that to help guys like you, noone on this website can help us with our tune up but I dont mind giving advice to guys who dont know as much about nitrous.
You go with what you think is right and you can learn the hard way like most of us have.
Ive learned 90% of what I have learned from here, rather it be N20 or putting everything together. This is the 1st car I have ever raced and after a few times, I couldn't stop and pretty much everything I have read on here, has got me to where I am today.. .. I am not hear to bash anyone. I see that there is more then one way to skin a cat when it comes to N20 I suppose. I read and make changes at the track and see what works best.
All depends on .... Fuel, plugs, cam, head and finally shot size.
Change any 1 of those things and your timing needs will change.
What timing would you use for a 300 shot on pump gas?
28* on motor then -12* for your 2per 50hp = 16* wouldnt make it to the 1/8mile I bet. See how that works.
