What happens when u spray on.....
why dont you ask what part you should run for a given need/goal? asking hypothetical and you will get silly answers to silly questions
if you are not ready to change out plugs on a regular basis - then you arent ready to run nitrous. we are here to help. i wouldnt run anything hotter than a TR7 plug for a nitrous application
On a stock motor, with a stock tune, running a 100 shot on a TR-55 plug, wet shot should not have an issue, actually it would be better to use the TR-55 vs a Factory plug due to the meterial used.
Still remember when you run the bottle that you are prepared. I plan on always using a stand alone fuelcell in the front that is filled with C-16. So the fuel requirement will never be an issue and the plugs can stay in the TR-6 range and car would need a specific "Nitrous" tune.
But like i said before, get video of your adventures and report back please
Like mentioned before a colder plug will tend to foul up with low engine speeds, a stronger ignition system will help clean the tips and stop build up but with a really cold plug for the big hits changing plugs is inevitable. A colder plug will take just a bit of off-bottle performnce but u wont be able to "feel" it, the timing that needs to be takin out wil make more of an impact, unless you have a race engine where every 1/8 of a hp counts dont worry about it but if you had a race engine it wouldnt be running a TR55 or 6 anyway. Hope this helps
