Problems with HSW Standalone
I just replaced the relay, that is the first thing I did. I tightened up the nylon thing and I think it solved it, but when I tried it again I didn't let it build over 3 PSI because I saw smoke from one of the wires and shut it off right away.
Yikes.... Maybe the pump is on its way out and is drawing too many amps?
How could I tell if the pump is in fact going bad?
Dave
Nick
I rewired the relay using a larger gauge wire. I put a 25 amp fuse on the power side of the relay. As soon as I turned it on, I heard the relay click and then the fuse immediately blew. Hot wired the kit and it turned on but the wires coming out of the standalone got really hot. The power wire and ground wire after that did not get hot, only the wires coming out of the cell. I drained all the 110 and removed the pump. There is a lot of rusty crap at the bottom of the tank. I kinda figured that would be filtered by the filter at the bottom of the pump though.
I'm stumped and don't know what to do.
Nick
