Attm: HSW guys or anyone that had there solenoids rebuilt
I had my solenoids rebuilt buy HSW and I just got them back today. In the box where two of these (one's alittle different):
![](http://i177.photobucket.com/albums/w229/pgrasso/CIMG0202.jpg)
![](http://i177.photobucket.com/albums/w229/pgrasso/CIMG0205.jpg)
What are they? They look like the plunger but if they were suposed to rebuild them why did they send them?
Also,
They did not take the NPT fittings off or the bracket. Do you need to inorder to rebuild them?
Also,
Those are your old ones, the new ones were installed. We provide them back to the customer so you can see that they were replaced. As for the fittings I don't remember seeing anything for removing the fittings on your note, we ususally don't offer that kind of service. You can use a little heat to heat the fitting to remove it.
These solenoids that Paul sent back in for a so called rebuild were on my C6. I did not even use one full bottle with this brand new plate kit that I purchased from you all. I pulled off the kit when I decided to do a stroker build. Why would brand new solenoids need to be rebuilt after not even one bottle of use? If you would like, I can PM you my name, address and so forth so that you may look up my purchase.
Thank You,
Mike
